Results 1 to 2 of 2
Thread: Wiring Two Driver Side Radiator Fans
    Northern Virginia
    Just looking for a quick answer on this; when wiring in two driver side (stock) smaller fans will they pull more power than what can be supplied using the power wire from just the passenger side fan? This is when them hooked up to perform like stock (stock resistor in place). Just curious if I might need to run a power wire straight from battery in the case the stock power wire is not up to the task.
    Apr 2011
    Mid-April 2011.
    Monroe WI
    I'm running two driverside fans. (AKA a/c fans)
    I have the driver side mounted fan wired up normally (just plugged in) and the Passenger side fan is wired up the way way the NORMAL passenger side fan would be.
