A Pi or NUC would obviously be a much better choice, merely pointing out that I've finally figured out something a Haswell would be better suited for than Ivy or Sandy Bridge![]()
i recently upgrade from a 3.9ghz 920 (also under water) to a 950 on the cheap to give my rig a bit more life. I'm going to wait for the next LGA 2011 chip to come out and then upgrade to that.
it's biggest gains are lower energy consumption, IMO. the next iteration of the tick-tock cycle should have more noticeable performance improvements for the 1150 chipset (hopefully). so far, I'm not inclined to go 1150... I also like having many pcie lanes available =D
edit: graph!
-jeff
1992 SVX LS-L
1996 3000GT FWD-TT
2005 XC90 T6 AWD
i collect parts.
Of course, something to note with the graphics, is that the 2600K and the 3770K overclock slightly differently than the 4770k. And of course after you get above 4.0 or 4.1ish, the power consumption is actually fairly close between the different generations.
At 4.5ghz for instance (which is realistically about as high as most enthusiast could expect to OC):
2600k - 150W
3770K - 168W
4770K - 142W
Honestly, for what power costs (here in TN anyhow), 8W a month difference between the 4770k and the 2600K would take a long time to recoup the differences of paying the premium for a new 4770K
Meh, PCI lanes means nothing to me at this point. 2 cards makes the CPU the bottle neck. Beyond that is kind of a waste. I'll probably wait a few months and switch to a used 3570k for the significantly lower power consumption over the 920 with better OCing temps. I think at full power I consume somewhere north of 200W from the CPU. Would go with a SB-E design (or IB-E pending what happens when it actually launches around Sept or Oct), but the bang for the buck really just isn't there IMO.
I agree that next year's upgrades *should* be more powerful, but again, now that AMD is all but out of the CPU game, there's no point for them to invest resources. They stand to make more money by focusing on low power consumption versions that are more scalable. Of course, again, with just one dedicated graphics card, even monsters like the 780GTX or the HD7970, the graphics card is still the bottle neck. You need 2 graphics cards to remove it as a bottle neck. And by that kind of monetary investment, you are probably running a six core unlocked i7, a crapton of RAM (even if it's a waste), SSD and Raid10 hdds. It's kind of like guys who complain about how "weak" the 2 bolt motor is without realizing the amount of HP it takes to exceed the capacity of the block requires such a large amount of money and mods that spending more for a 4 bolt (or upgrading the 2 bolt) is a drop in the bucket.
I had been limping along with a Q6600 with a mobo that was starting to fail, so I'm now rocking a 4770K. Haven't really started tweaking too much, but got a 4.3 OC at 1.2V. I'm pretty certain 4.5 will be easy to get once I start cranking the voltage more, but I'm going to enjoy using the machine for now.
For the power thing: It's not about power use at full load, it's about the use the rest of the time. Sitting here right now, this CPU is bouncing around 800MHz and 0.7V I've seen it drop to 700MHz and .5V with 1 core and about 15*F above ambient (under a 280mm rad setup, though). For most people, this chip IS going to be a power saver because no one is using 100% utilization all the time.
The other benefit is using this with Win 8 I'm seeing cold boot times of about 7 or 8 seconds tops. By the time my LCD turns on from it's little start animation I'm already at the login screen. That's more a product of the motherboard and chipset, but definitely something that I like.
With the race to get x86 into tablets, better ultrabooks, and other things like that, I wouldn't expect to see any major game change in a while. Broadwell is already being seen as just a notebook processor. Let's face it: The market is shifting from large, powerful desktops. People like us that want high end machines are disappearing and Intel is following the market. not much we can do there.
I just picked up a 3570K and it is a fantastic chip. Lightning fast for my Media PC setup. The gal at the store tried to get me in to the Haswell chip but I went with my gut and stuck with the Ivy Bridge. I picked up a mini-itx board and got it booted. I actually needed to down clock the CPU because it was hitting thermal shutdown due to the size of the case and the poor ventilation the case provided. Still at 3.0 GHZ it flies.
Haswell *might* have been a good pick up for you (pending the price difference of course) because it will run cooler and use less energy, especially if it spends the majority of its time on standby. However, I don't take a chance with new launches, there's usually problems. As an aside, have you considered running a self contained liquid cooling set up for the CPU? Will be quieter and cooler than just about any air cooled system.
Power use at full load IS a concern when you use your PC for folding when you're not using it..Admittedly when I'm just dicking around and browsing the web it's not at full load, but the computer probably sees at least 75-80% of it's time at full load. And to make you feel marginally better about your 280 rad on your CPU, I currently have a 240 and a 360 that are just cooling chipset and CPU at the moment. Plan to include a block for the graphics card down the road, just not int he budget right now, so my CPU cooling is overkill.
As far as cold boot times, I can't speculate what the difference is. I'm sure chipset and motherboard have a lot to do with it, if you're running a SSD that's a huge boost, CPU may have something to do with it as well. Also depends on if you're running W8 or not.
Pity that they aren't catering to high end enthusiasts though. Given the shape console gaming is heading, this would be a hell of a time for them to endorse PC gamers.
Unfortunately main stream money making pc buyers don't care about full load power usage and 24-7 load. We're not the target any longer. Intel made the stupidly overprices E series chips for those people, not realizing that most enthusiasts don't want/need 6 core quad channel power hungry monsters like that. We're an afterthought and a niche market. I'm hoping the Steambox will open the door for some high end enthusiast chips from Intel to combat the new consoles. As for the cooling: I don't feel bad about being under water, was only advising I'm under water so that there's no assumption that I'm running that cool under air. I knew better than to try and put this chip on air.
I also think the power usage may be a little overblown. 1.2V, 4.5GHz, HT on, 100% load using AIDA64 HWmonitor is showing 70W load from the CPU. How accurate that is I'm not sure, but it looks nice to me.
Yeah, using SSD, W8, all that good stuff. I know better than to think that this is a product of the CPU only and not also the entire platform, but to have the platform you need the CPU so it's all symbiotic. With SSD on my old build and Win 7 or 8 it would take about 27 seconds from button to login screen, so that is what I have to go off of.
For me, the choice of haswell is mainly the fact that it is using far less power sitting here right now typing this out, it's a new platform that will hopefully last more than one generation (like IB on 6 series boards), and with the OC I got I would have to have got an IB to 4.7-4.8 or an SB to 5.0 to match the performance I get now. Definitely no buyers remorse here.Maybe a new stepping will get released that allows better OC'ing and I can go even higher!
I can't run a liquid cooling setup because the case is tiny. It's a Media PC case which has very little room for even air-cooling. The water cooling would have to be externally placed and that isn't ideal. It doesn't need to be very fast, just fast enough to stream music, play videos, etc.
Jeremy, just had a thought: Do you think maybe Intel decides not to solder the IHS on future chips because average user won't notice and they would rather OCers and such do it and thereby void their warranty?
Dangerous thoughts, I certainly hope that's not the case. Still have my hopes high for rebuilding the system around Black Friday. I'm hoping for a combo deal with a new case, IB CPU and mobo, RAM, mid level graphics card, power supply and SSD. Take my old i7, mobo and water cooling system throw it in the new case with the new power supply and new graphics card. Toss in my old 500gb hard drive and someone has a complete PC that could pay a significant chunk of the cost of upgrading.
