Results 1 to 4 of 4
Thread: Over Boost fuel cut values?.
    Hello all, nice to see the flashable ecus doing so well!.
    Just a quick question, is the Overboost Fuel cut set up with a table and is there anyway to find out hz vs rpm for when it cuts in?.
    I'm running nitrous and need to avoid hitting it at all costs..
    Yes, there is a table. It is in load % though. Greg could probably give you a rough idea what % translates to HZ better than me;
    500 162
    1000 162
    1500 168
    2000 172
    2500 192
    3000 210
    3500 205
    4000 202
    4500 198
    5000 198
    5500 198
    6000 198
    Due to many variables there your load vs hz may vary. I also do not understand why, but the relationship between load and hz is not constant, probably due to rpm, but here are a few samples from my logs
    115 load 566 hz 2718 RPM
    155 load 904 hz 3281 rpm
    189 load 2000hz 5500 RPM
    167 load 2154 Hz 6781 RPM
    This is at roughly 15-16PSI (my logs show 13, but the gm map sensor seems to read 2 PSI lower than my defi gauge)
    let me know if that helps any, I have tons of datapoints. I have peaked about 234 load so far, but I have raised the values in the table to prevent fuel cut.
    I lack color... verified
    Aug 1998
    Load is HZ * MAF size / 65535.
    Disable fuel cut by setting the timer to 10000ms.
    Tune your car.
    Log load.
    Adjust the values in the fuel cut table to be about 10-20 load higher than your logs.
    Reenable fuel cut by setting the timer back to 1000ms (or less if you prefer)
    Thanks for the replys!, I'm still on my 1st gen Ecu so cant do anything about the hardcoded table but I have a Hz output table that the car is running from (via EMU) so I was after an idea of max hz for the stock system.
    My max hz in the table is 2200 at 7000rpm 30psi, I basically cut the airflow in half to avoid fuel cut and make tuning the 1200s easier.
