Results 1 to 3 of 3
Thread: Brake lights not working
    So a local friend is coming back from overseas soon and he asked me to do some maintenance on his Spyder before he returned. First thing I notice is his brake lights do not work at all. The tail lights work fine, however, when the brake pedal is pressed, no brake lights. Turn signals,headlights, and night time running lights all work. I have checked all the fuses related to the tail lights and the relay. I swapped out the brake light switch with a working one and still nothing. Another thing I noticed was that no interior lights work when you open either door(door lights, courtesy lights). Also no lights are operational without the key in(running lights, headlights,turn signals, ect). It has been a LONG time since I have driven one of these cars regularly but I am 99% sure that these are supposed to operate without the key being in the ignition.
    I haven't had time to really dig into it yet, but I found a turbo timer and random alarm modules shoved down in the driverside foot well area. I will probably be removing these depending on what he says, but the brake lights worked while all this crap was plugged in down there so I don't see that being the issue.
    Hoping someone has overcome a similar issue before I spend a bunch of time tracking this down.
    Thanks!
    Learn how to Powder Coat at www.powdercoatguide.com.
    buuuump
    I lack color... verified
    Aug 1998
    The alternator fuse is blown. Its the white 100amp fuse in the box under the hood near the airfilter. This will fix the issue with the interior lights.
    If replacing that fuse doesn't fix the brake lights, I suspect the culprit is the brake pedal switch. If you crawl under the dash and follow the brake pedal up to the pivot mount, you'll find the switch. Chances are the pedal isn't making good contact with the button or its worn out and doesn't work anymore.
  4. The Following User Says Thank You to Greg E For This Useful Post:
