I've made a few posts lately about fueling problems and stand alone computers. I have two more issues/problems YAY!
1. How do I set/verify the ignition timing? I have the CAS but everything I read on stealth 316 doesn't really help. Will it be in my service manual? (I don't have access to my service manuals at work). It idles cold at about 2000RPM. I hoping that if the timing is off I can fix some RPM issues.
2. The car is backfiring. Alot. REALLY loud. My O2 sensor is reading about 1.04 Lambda. If I richen up the tune a wee bit would it help the backfires? It is sitting with only the downpipe on but I don't think that would cause any backpressure problems because the tiny td04 turbos should supply enough backpressure. Also could the timing be causing backfires too?
I don't mind letting it warm up with a high idle but the backfires are stupid loud and Im afraid harming the engine. I don't think that its a vacuum leak causing the high idle because I fixed all those I could find and it brought the idle down from ~2700RPM.
This website has been a big help in getting this car running and I'm hoping you guys can pull through again. I'm hoping you guys teach me enough so I can be of help in the future.
