Hi folks,
I seem to have pressure in my fuel tank. I went to refill the gas tank today, and when I opened the gas cap, it seemed to release a good amount of pressure. I've got a 92 VR-4, with a 93 engine, and running Chrome 2.0. I am running all the factory vacuum lines and EGR/Purge. For the purge solenoid, I swapped in a solenoid from a 96 non-turbo 3000GT. I'm assuming there should be no pressure in the tank, and it should be let go by the purge solenoid. Later model VR4s also had a one-way valve and different purge setup to that charcoal cannister. Does anyone have experience with this? Perhaps, I need to change something related to when the purge solenoid purges? Or, perhaps install a one-way valve on the charcoal cannister? (Maybe boost is getting into the tank?). This is above my knowledge level, and I'm just randomly guessing.
Does anyone have any thoughts?
Thanks!
quick solution was to not close gas cap tight.
