Results 11 to 20 of 21
Thread: Custom Built Car PC's?
    It lists them...
    " - Dolby Digital 5.1 5-Volt preamp outputs (front, rear,
    center, sub)"
    $2500.00
    Twin Turbo verified
    Melbourne, Australia
    There are also a few other issues with it. It only has g wireless, it's running Vista , only has GMA 950 graphics [which they say is good hahaha], has a PCMCIA slot which is defunct now. Should be an Express card slot. However the OBDII & CANBUS interface option is cool.
    Twin Turbo verified
    It lists them...
    center, sub)"
    Ahh missed that. However that price is a tad high for me
    $2500.00
    That's fricking crazy! OP make us one under 800 bucks.
    Twin Turbo verified
    I think i'll just use my eeepc with a touchscreen mod. What I really want is a standard head unit with dvd player and touchscreen with usb touch screen control so then I can put a mini pc in the glove box and have the audio come through the head unit and all controlled with the touchscreen. Simply play cd or dvd on head unit then if i want gps or mp3 etc it can be done with the pc.
    Has anyone seen a head unit that can do this?
    No Show NG11 Not Verified
    Mesa, AZ
    Quote Originally Posted by HondaKiller View Post
    I heard car pc's and it brought this to mind.
    I am not a fan of Mustangs or ipads but this is a very clean setup. I am a bit jealous..
    Your 1993 Mitsubishi 3000GT SL is one of 4310 that received VIN numbers. Based on the order of the serial numbers, your car was the 2685th out of the 4310 that were made that year.
  8. #18
    Herkimer, NY
    I'll put together a list tomorrow with a final base price.
    1991 Stealth R/T TT
  9. #19
    Twin Turbo verified
    this is what I want.... it does everything as a head unit then just add a pc. Acts as a normal cd/dvd player headunit then allows full touchscreen control via usb for the pc and even allows cd/dvd-rom function for the pc using the internal drive. has built in amp etc.
    http://www.xenarc.com/product/MDT-X7000.html
    Features
    * For In-Car entertainment, In-Car Computing
    * TMD Automotive Grade LCD Panel
    * Fully motorized screen with Tilt adjustment
    * Built-in 55w x 4 amplifier
    * Built-in CD, video DVD player
    * Built in DVD decoder with Dolby Digital 5.1
    * USB DVD-ROM in PC mode
    * Built-in AM/FM Radio Tuner
    * 5-wire resistive Touch Screen (USB)
    * Multi-Monitor Touchscreen Support
    * DVI Input x 1 / VGA Input x 1, AV Input x 2
    * PC Audio input x 1, AV Output x 1
    * Built-in 2 port Front Access USB hub
    * Multi-function remote w/ PC media playback control
    * Front panel PC Power switch control
    * On Screen Display Control via Touchscreen
    * NTSC / PAL Multi-System
    * 16x9 Aspect Ratio
    * High Resolution Display
    * Night time backlight dimmer for night-time use
    * High Performance Video and VGA Processor
    * High Quality Scaling & Anti-Aliasing
    * Automatic display adjustment
    * Anti Glare Coating
    * "E" Mark Certified for Automotive use
    Specifications
    * Model #: MDT-X7000
    * Screen Size: Diagonal 7" (16:9)
    * Physical Resolution: 800 (H) x 480 (V) WVGA
    * Supported Resolution: 640 x 480 ~ 1024x768
    * Dot Resolution: 2400 x 480 = 1,152,000 (dots)
    * LCD Brightness: 400 cd/m²
    * Touch Screen Interface: USB port
    * Operating Voltage Range: DC 10V ~ 16V
    * Power Consumption: 120W
    * Operating Temperature: 41°F~131°F (5°C~55°C)
    * Storage Temperature: -22°F~185°F
    * Dimension: 1-DIN: 7" (W) x 2" (H)
    * Weight (lb): 3.97
    * FCC, CE, E13 Certification
    * ROHS Compliant
    * 12 Month Warranty
    * 30 days No dead Pixel Guarantee
  10. #20
    Owosso, MI
    That's too bad it's a flip out.
