Results 11 to 20 of 21
Thread: DR650 Set-up
    Feb 2011
    Scottsbluff, NE
    As far as the clutch goes, I would stay away from SPEC... I have had a SPEC stage 2 and it only lasted 10-15K before the disc partially melted to the pressure plate. Personally, I would go with the RPS Maxx with either the 6-puck or the OEM disc. I'm sure there will be other things you are going to run into as well.
    One thing that was mentioned was the MAF, you'll want to upgrade that, IMO a GM MAF would be a good idea to help free up more airflow and make more power than with the Montero MAF.
    What fuel are you planning on running? To truly take advantage of your billet turbos, you would need more than just pump gas.
    Another thing to consider is if you will be launching the car you will need to upgrade the trans/t-case with at least a bellhousing brace if you're 6-speed or a transfer case brace if you're 5-speed.
    If I think of anything else I'll post it.
    1995 Dodge Stealth R/T Turbo
    DR650 Set-up
    Quote Originally Posted by DK77 View Post
    This, but not so sure an oem clutch will hold what you are going to see power wise. I went with Ninja, and a South Bend 4fe. I will be using the Montero maf, and if it seems inadequate a gm or similar with maft goes in.
    Edit: reading failure, rps with an oem style = good, not oem clutch for the power.
    Oct 2010
    96 Stealth TT/97 VR-4
    Quote Originally Posted by daerdevil_1987 View Post
    Okay let's see
    • DR650---------------------------------Dynamic Racing
    • ECU-----------------------------------Chromed ECU | 3SGTO Flash Tuning
    • Palm/notebook/laptop------------------ASUS Eee PC X101CH-EU17-BK 10.1" Netbook Matte Black - Newegg.com
    • Boost control--------------------------Using ^^^^ but i like the psychical one ( any ideas )
    • 560cc Injectors------------------------EVO injectors
    • MAF-----------------------------------EVO/Montaro
    • Fuel pump-----------------------------Walbro 340 or Denso + hotwire kit ( Ninja )
    • Fuel filter------------------------------Come with the fuel pressure regulator and gauge www.maximalperformance.com or
    • Fuel pressure regulator-----------------Ninja Performance FPR/Gauge/Filter Dual Feed Fuel System (NP-3SDF) - Ninja Performance - Affordable
    • Fuel pressure gauge--------------------^^^
    • Wind Band-----------------------------PLX DM-6 SM-AFR | Wideband Air Fuel Gauge
    • Air/fuel gauge--------------------------APEXI SAFC 2 or Neo
    • Boost gauge---------------------------^^^^
    • Turbo timer Type 1---------------------Not sure about that yet HKS Turbo Timer - Type-0 & Type-1*-*Mitsubishi 3000GT*/*Dodge Stealth Parts
    • Oil pressure----------------------------I guess any kind
    I'm trying to keep the stock look on the car so most likely I'm going with the side mounts. I'm keeping the stock ones for now but I'm changing them diffidently.
    Keven If I keep the one I have I need to get rid of the Cat, maybe that all what I need to do.
    Is this for a 1g or 2g car? Maybe add a bellhouse/TC brace, and also a HKS DLI ignition advancer.
    The Toys
    Feb 2011
    Scottsbluff, NE
    If you aren't running more boost than you can on pump gas, you shouldn't need an ignition amp... just make sure your stock ignition is all tuned up. A good stock ignition *may* be able to handle up to 25ish psi, but an amp would make sure you have the needed ignition power.
    Mar 2012
    Delaware, Ohio
    It's 97 as for the clutches I heard some good things about stage 4+light from 3sx one of my friend have that and he love it so I have that to think about .
    Feb 2011
    Scottsbluff, NE
    I've heard (and experienced) a lot of horror stories about SPEC clutches for these cars. They seem to be designed well, however they seem to have spotty quality control. More than one person has had the rivets holding the friction material to the hubs come out and ruin the clutch.
    Delaware
    As far as clutches go, you can do a few things. Buy a new OEM disc and a ACT pressure plate and have a great smooth setup. Or for a little more grab, the RPS pressure plate. The OEM disc + RPS PP is what the street maxx clutch is fyi.
    I highly recommend the RPS street max clutch.
    Ignition wise, 18-19psi was the limit with a healthy gap(.032) with all brand new coils and wires. Im not a fan of gapping plugs way down to avoid blow out.
    Having a 6spd w/o a bellhousing brace is financial suicide because odds are you WILL break it which will ruin the whole trans. Cheap insurance.
    I would use the AEM wideband personally.
    Jason
  8. #18
    Wilmington, NC
    Quote Originally Posted by Ange View Post
    or you dual core fmic and hook it up to oem piping and you don't have to deal with surge issues. paint it black for discrete look. good for 700hp. I can recomend the kit that oohnoo on here sells.
    decent smics cost alot. save your money for other mods unless you're loaded. the dsm's are old now and usually not in great condition.
    just my 0.02$...
    +1
    My dr500s heat soaked my stock ic's after 1 gear pull at 15psi. In summer I had to run at 11-12psi or else I would get knock. With Bob's dual core I see no knock at 17psi, and blacked out its barely noticeable from the front, and the engine bay looks stock.
  9. #19
    Mar 2012
    Delaware, Ohio
    Quote Originally Posted by 75blackray View Post
    +1
    Yea I was thinking about that , I'll buy that when I buy the turbos all togther.
    As for the clutch, what do you guys think of the clutch master 725 ?
  10. #20
    Feb 2011
    Scottsbluff, NE
    You really shouldn't need a twin disc clutch... Just go with the RPS Maxx Street (full face) for $630 (with TOB) from GZP RPS Max Series Clutch | Ground Zero Performance
    Then if you need it, just get a Ford 1" 23 spline alignment tool from a local auto parts store for a few bucks (if you don't already have one)
    That should be plenty of clutch for you and it should last for a while since it's got an OEM disc.
