Had a question for the gurus on here. Rebuilding my motor and it should be done here in the next week or so once these last few parts trickle in. With this rebuild, I also had to replace my flywheel and clutch as both were worn well beyond factory specifications. The prevailing school of thought to break the motor in is to let it reach operating temperature, change the oil. Then do 20-50 miles of 2nd, 3rd and 4th gear pulls and use the tranny to decel for vacuum to help seat rings as well.
However, I've also heard for breaking in a clutch/flywheel that you don't want to engine brake it. Not sure what the logic is as the synchros should handle most of the abuse of that, but looking for input as to what the steps are for breaking in a new engine, flywheel and clutch all at once.
