got another question.
has anyone ever attempted to make a stroker 6g72 out of a 2-bolt? i'm trying to source a 4-bolt specifically because of this.
91 R/T TT
interesting. i had my suspicions that the 2-bolt block wouldn't work. anyone got specifics?
They are metal brackets from the engine block to the bellhousing.
afaik the brackets would fit 5 or 6 speed on a 4 bolt. They made the brackets wider to clear the wider engine girdle and oil pan, but the trans bolt holes should be in the same place.
3sx would know best about the awd atx.
i would add a 4 bolt rear main seal case, lower timing cover to the list and a hand grinder. you need it for the rear tranny dust shield and the a/c bracket. i used tin snips for the oil pan dust shield. you need to notch it like so. you could use a file if you have alot of time,lol.
http://i287.photobucket.com/albums/l.../crixus037.jpg
