Page 9 of 20 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 195
Thread: Now Another Problem.....
  1. #81
    This is a pic of the old plug for the MFI. Pin 6 on this diagram indicates that it's the ground. It's the only black wire on the entire plug. But where does it go to??
    Edit: And is it just me, or does it look like in this pic that pin 6 is an outside ground for that relay in addition to the ECU ground??
  2. #82
    Well I understand you thought but the ECU is bolted to ground. And the fact that the ECU closes and then holds the MFI for a amount of time tells me it is able to supply that ground when it wants to. This tells me that for whatever reason the ECU is giving up the ground or the power is being pulled. I am leaning towards the ECU having a issue. I just dont know for sure.
    I would have thought ECU as well, but I tried a known good NA ECU, that, while it wouldn't function properly, will, if I understand correctly, at least keep the motor going. But the exact same thing happened. Which makes me think that there's a ground missing somewhere. But the question is where? Why would the old MFI have a ground and the new one not?
  3. #83
    Canaan NH
    It seems that pin 6 runs a alternative coil for the fuel pump relay. I do not know what it purpose is. What MFI are you using, the one in this schematic or the one for a 91 model ? You might try tying pin 6 in with pin 7 on this diagram.
  4. #84
    The one right above is the 91 wiring diagram, and the one on page 7 is from the 94. I'm thinking you're right. Pins 7 and 6 should be spliced together to create a proper ground, which would explain the issue here. The wire orders change from 91 to 94, so I posted them both to compare. I'm going to ground pin "7" (in reality, pin 5), and see what happens.
  5. #85
    ROFL. OK, so I grounded it, and it starts up, revs really high, dies, and then I can hear what I think is the fuel pump (only motor in that area) kicking into overdrive, and continuing, until I pull the key out.
  6. #86
    Canaan NH
    Yeah thats because you GOUNDED the pins to the MFI lol. The ground is to be supplied by the ECU to pin 7 not tied to ground itself. I think the problem is with pin 8 not holding ground from the ECU try grounding that wire and see what happens.
  7. The Following User Says Thank You to CoreyB For This Useful Post:
  8. #87
    No change. Lol, should I just start grounding out every pin?? I did your "hillbilly" method, and I got it to run constantly, by holding down one of the relays. One relay goes, then the other follows, thus causing the fuel cut. The first one to go is NOT the fuel pump relay. It's the other one. Where does that lead to?? Also, when I was holding it down, the RPM's kept creeping higher and higher. I figured at 2500 RPM's, I should stop it. What's causing that? Could it be the resistor pack for the injectors?? First things first though. What does the other relay control?
  9. #88
    Here's a stupid question. On the 94 MFI diagram (page 7), is pin 3 (red wire) grounded to a common ground?? Is that what I'm seeing?? If that's the case, should I try grounding it??
  10. #89
    Canaan NH
    The other one is for pin 8 to the ECU. Its the one I suspected. I dont know why the rpms are climbing, thats a different issue. Was this car a TT to start with ? The relay in question supplys power to the ECU which the ECU supplys the ground to pin 8 to get. I have no idea why or what the power is needed for.
  11. #90
    OK, so I'm kind of confused now. Are you referring to pin 8 on the MFI or the ECU?
