Page 19 of 20 FirstFirst ... 917181920 LastLast
Results 181 to 190 of 195
Thread: Now Another Problem.....
  1. #181
    And with the grounding of the pin off of A-55 has come a new issue. There is no power to pins 1 or 3 on both relays. That means that the temp switches are working correctly, and grounding when the engine gets hot enough, but there's no power getting to pin 1 for the relays to close.
  2. #182
    Canaan NH
    Blown fuse. Its a 10A fuse. Think its under the dash. Print says its #3 not sure if thats right or not.
  3. #183
    Nicely done!
  4. #184
    No change though. And the weirdest damn thing happened. I turned the ignition to ON, and the damned AC fan started up? Then I started the car. And it turned off?
  5. #185
    Canaan NH
    You dont still have connections going to the ECU do you ? If you do it would just blow that fuse again. 53 an 6 can not be hooked up to that ecu.
  6. #186
    I do. And the fuse still hasn't been blown. Pins 3 and 6 are in no way associated with the relays or power from the relays. THey're just 5V. And now I can't jump pin 5 to start the fan anymore....?? The power to it is weak and erratic.
  7. #187
    And now it's strong and holding steady??
  8. #188
    Canaan NH
    Can you tell me what pins you are spliced to on the ECU ?
  9. #189
    C-29, pins 3 and 11. They lead to pins 6 and 53 on the ECU
  10. #190
    ROFL. The DRIVER'S side fan kicks on when the temp hits 190, brings it back down to about 182.
