Page 11 of 20 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 195
Thread: Now Another Problem.....
  1. #101
    But I got it!!! I had pin 9 from the first diagram wired to pin 8 on the second diagram, instead of jumping pin 4 to pin 8!!!! She runs!!!!!!!!!!!!!! Thanks for your help!! Couldn't have done it without you!!
  2. #102
    Canaan NH
    Thats great news man.
  3. #103
    Thanks again for all your help. Now for the tuning phase!
    Here's what I've seen so far:
    -at what water temp does the radiator kick on?? The water hit 200, and it never turned on. I turned on the A/C, and the driver's side side nothing either.
    -it idles at 1200 RPM, even with the ECU reset, and the idle control screw turned all the way clockwise (decreasing RPM's)
    -white smoke coming out of exhaust. It DOES have a walbro 255 on a stock FPR. That might do it right?? Unburned fuel?
    -my UEGO fluctuates pretty wildly when the engine revs, upon acceleration, it hits about 12-13, and at idle, slowly creeps back up to 17+. Having never owned one before, is that normal??
  4. #104
    Canaan NH
    I think the fans should have come on, definitly with the A/C. Check the fuses, I think at least one of them is under the hood on the drivers side. You should also check that they are plugged in. The coolant temp sensor for the fans is on the water neck.
    It sounds like the ECU is not getting the coolant temp signal. It thinks the engine is always cold causing the high idle and lack of fans. The walbro has nothing to do with the running rich or high idle, you get a little better flow capability with it but it wont over run the fpr or the injectors.
    You shouldnt adjust the idle screw with out setting the TPS at the same time. The TPS has a switch in it to tell the ECU you are at closed throttle, when you make the adjustment it can make it so you never hit the switch or it opens late into giving it throttle. Try loosening the two 10mm bolts the holds the throttle cable to the intake plenum, it is on a slide adjustment and its possible its holding the throttle open.
  5. #105
    Ah, but I have a 94 body and a 91 harness/ radiator. where should I tap the signal for the coolant temp sensor for the radiator?? On the radiator where the sensor is, or on the water neck?
  6. #106
    Canaan NH
    Check for power at pin 5 of the radiator high and low relays. The plug is shaped like a T 5 being the bottom of the T. They are located in the fuse box under the hood passanger side.
    I was mistaking about the water neck sensors controling the fans. Seems they dont.
  7. #107
    There were 4 pins in each relay, and there was power to all the pins but the middle one in each relay.
  8. #108
    Also, i drove it around the block to test it out- it dies when I brake?
  9. #109
    Canaan NH
    Sitting still hitting the break, what happens ?
  10. #110
    Nothing. I think it's because the TPS hasn't been adjusted yet. When I brake while moving, the RPM's drop down and don't recover.
