Page 10 of 20 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 195
Thread: Now Another Problem.....
  1. #91
    Canaan NH
    Mfi...
  2. #92
    Canaan NH
    Pin 7 is not a ground. it is 12v positive, at least thats how I see it.
  3. #93
    Just wanted to make sure. I was confused as I was looking at the 94 diagram, and then realized you were looking at the 91 diagram. Moving on though. Pin 3 (or 5, on the 91 diagram), should be straight grounded, correct?
    If the ECU power is the issue, is there a way to bypass the relay??
  4. #94
    Canaan NH
    When pin 5 of the mfi is grounded it energises the coil for the fuel pump relay. This then sends power to pin 1, which goes to the fuel pump. When looking at these schematics think of it as if the coil is in the pic is both grounded and has power it will pull the little switch toward it.
  5. #95
    Canaan NH
    Nothing on the MFI is straight grounded. Only grounded through transistors in the ECU.
  6. #96
    But on the 91 schematic (page 9), the black wire at pin 6 was straight grounded, wasn't it?? If not, where does that lead to?? I ask because pin 7 on the same diagram heads to the ECU.
  7. #97
    Canaan NH
    Off of which diagram ? lol my head hurts. Post the diagram you are talking about and I can answer which pin does what.
  8. #98
    OK, so this is the 91 diagram. Notice how pin 5 (red wire) seems to be grounded?? Same with pin 6 (black wire)??
    Now this is the 94 diagram. It looks like they removed the ground for the fuel pump relay (black wire), and left just the ECU ground (red wire). My question is, are those two wires straight grounded?? Because it doesn't look like they go to the ECU. It looks like pins 2, 5, and 6 go to the ECU on this diagram, but not pin 3. Am i correct in this??
  9. #99
    Canaan NH
    You are correct that pin 3 does not go to the ECU, however this is not a ground but power which also goes to pin 2 which does goes to the ECU.
    In the first pic pin 5 I dont believe to be grounded. I cant tell where it goes to but it is likely supplying power to something.
    Pin 6 is getting a ground from somewhere but I dont know where or why. It does the same thing as pin 7 on the mfi, all from the first pic.
    Second pic, pins 6 and 5 are ECU supplied grounds pin 2 is power to the ECU.
    Hope some of this makes sense. Last post tonight but would be willing to help in the morning. Hope I have been at least some help so far. Its difficult when you cant personally be there to work on it.
  10. #100
    It does indeed. Thanks for you help and staying at it. I'll post updates, but hopefully I'll have it fixed by tomorrow. If not, we can have more "fun"!
