Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: ABS Delete
    I did my abs delete about 1-2 months ago. I managed to use oem lines though with the engine in. It wasn't too bad except you need to remove the steering column (just enough to pull the linkage from the steering rack) so you can slide a brake line behind it, and the brake booster needs to come out. I didn't swap the master cylinder to the non-abs one. I don't know what the difference but they do have different part numbers. My brakes work just fine. I didn't have to remove my heater core hoses, throttle body, or intake manifold but I can see how it would have made it a little easier to get to the prop valve.
    St.Louis
    I used the STM kit and I like it a lot, pedal feels nice and tight. Ive been running it for 10-15k miles now and the lines are fine just looped through the 1 bracket in the wheel wells. Another thing that is great about the kit is you can disconnect the master cylinder from the brake booster and leave the lines connected so you would not have to bleed the system if you need to get to your clutch master cylinder.
    Driving Chris back.
    Well done, Eddie!
    So the STM kit will definitely work on a stock SL?
    94 3500gt vr2? verified
    NC
    It will work on any 3/s with ABS.
    STM is the easiest kit to install with the engine in the car. Removing the stock lines isn't too bad if you cut them. If you try to remove them without damaging them, it is pretty difficult.
    If you have the engine out, I'd recommend the OEM ABS delete kit. Cost is almost cut in half and keeps the car more original. Also, everything lines up perfectly and there are sufficient brackets to hold everything in place. If engine is out of the car, I'd probably go this route.
  6. The Following User Says Thank You to n2nsanity For This Useful Post:
  7. #16
    GREASE BUNNY
    VA
    Thanks for the write up!
  8. #17
    NC
    No prob. I feel I still need to tweak it and add a few more details and pics. I technically still haven't finished the job, lol. Still need to bleed the brakes and check for leaks. I started my tt conversion the same weekend, so it's been chaos ever since.
  9. #18
    Charles Town, WV
    I don't think anyone would try any other way, but it's important that you connect the front wheels to the port facing them.
    This allows the distributed braking pressure in case one of the lines fail. Front Right and Rear Left are on half the valve. Right Front and Rear Right are on the other half.
    Should be:
    Front Right and Rear Left,
    Front Left and Rear Right
    not
    Other than that, great writeup!
    Did you get this finished? How is it? Car is partially apart but still has motor, and I may be selling it, but I'm curious since it's convenient now.
    1995 VR4 Coupe
