Results 1 to 3 of 3
Thread: Stock MAF PPS limitation
    Wrench Monkey Not Verified
    Rochester, NY
    I've started increasing my boost and I'm having trouble understanding how to tell when I'm at the ECU's MAF PPS limit.
    There's a MAF Pulse Limitation in the code. This isn't a physical limitation of the MAF itself, just an issue where the ECU will stop adding fuel past a certain PPS (Pulse per stroke) due to a 1 byte limitation in memory. Beyond this limitation, the ECU will stop adding fuel so be forewarned.
    This limitation is 13.06 PPS or 319.7 grams of air/second (table is shown in the V2 xml). With a stock MAF, this is only about 450hp depending on which HP calculator you're using. This is coincidentally is about where the stock 3/S MAF also seems to run out of resolution.
    Is there something I can log or calculate to be sure I'm not exceeding this number while still on the stock MAF?
    I lack color... verified
    Aug 1998
    Your IPW will just level out and not increase. I doubt you're maxing the MAF. It peaks around 425-450whp.
  3. The Following User Says Thank You to Greg E For This Useful Post:
  4. #3
    Rochester, NY
    Ok good, thanks. I can keep going then, I'm only at about 350whp. I may not even need a new MAF if I can get to 450whp, not really shooting for more than that this year.
    How much whp did your 118mph Stealth have? I'm trying to hit 120mph this year.
