Results 1 to 10 of 12
Thread: Multi-Build Thread
    Appalachian Paradise
    Cool Multi-Build Thread
    Well, I'm a lazy ass, and unless I have a giant community of people to hold me responsible, I'm never going to get anything done. So, I'm putting a thread up detailing all of the things I need to do. This build thread encompasses my 2001 Galant LS V6, my girlfriend's 1995 Stealth Base, and my new 1992 Stealth RT/TT.
    I will post current pictures of each car, in addition to a list of things to do, in three separate posts below. I'm a turbo virgin, so if anyone has any advice they can offer me, I'm willing to take it, in addition to suggestions for parts.
    Well, I suppose I should post in order of completion priority. First up is the girlfriend's '95. It runs and drives great, so there's no real repairs needed. I bought the car from the original owner, with extensive service records, the original window sticker, and 167k on the clock. To get it running, I had to replace the fuel tank, fuel pump, clutch master and slave cylinders, and clean out the fuel lines. Not bad for a $500 car from the original owner. So far, I've put glass headlights on it, first gen R/T TT rims, first gen R/T rear and driver side, and a second gen R/T front bumper. Also has an eBay open-intake filter, and I've replaced some of the interior panels that were damaged by the sun with some slightly better stock parts. Also installed the flawless rear leather seats out of my '91, and painted the stock upper interior parts a light grey that doesn't quite match, but looks great.
    Some pics:
    The day we went to see it:
    After we took it home:
    Window sticker:
    Local meet with a few of the guys:
    With Stealthlabel in Charlotte, after installing the R/T front and rear:
    To-do list:
    new radiator hoses
    Remove and clean headlights, install 90mm CCFL halos (purple)
    Acquire fog lights (note, 3000GT fogs are NOT THE SAME)
    Install new dash, with aluminum dash vents.
    Recover headliner
    Convert interior to purple LEDs with Speedhut gauge overlays
    Tint windows
    smokinvr4 corner sub box with 10" sub and amp
    Better door panels (these are damaged at the tops)
    New front speakers
    Lowering springs
    Purple-stitched leather shift boot and ebrake handle
    Second gen SL premium cloth front seats (need a good driver side)
    Replace third brake light
    Paint outer A pillar covers, sail panels, and wing supports body color
    Paint rear windshield wiper arm
    Install SL dual exhaust, with test pipe and OBX headers.
    Install passenger side R/T side skirt and door cap
    Peel N' Seal trunk and interior (cheap Dynamat subsitute)
    Illusion purple powdercoated valve covers and miscellaneous accessories
    Illusion purple powdercoated calipers
    Black powdercoated intake plenum
    Insert spacers for the rear bumper (it sags in the middle, because the bumper support wasn't mounted properly)
    Tint rear lights
    Stealth rear wiper mod
    Possibly colored vacuum hoses, if they're available in purple
    Lower-priority:
    Full paintjob, black with purple metal flake
    New 18" rims, with neo-chrome lips
    Now, for the G. It's got a few problems, so its build is a little more intense.
    For those of you who don't know the platform very well, the Eclipse and Galant share the same platform, and are built in Normal, Illinois, which is the factory that built DSMs. The engine and transmission is oriented the opposite direction of the 3/S, with the transmission on the driver's side. My car is a 2001 LS model, with leather, an automatic gearbox, and a 3.0L 24V SOHC V6. I bought it last January as a daily driver, with 142,000 miles on it, for $4100. After a year of pizza delivery, it's sitting over 173k, and the engine is leaking water and oil profusely, smokes, and the transmission is clunking and very sluggish.
    The previous owner of the car performed absolutely zero maintenance, including basic cleaning, so I knew I was in for a bit when I got it, but had no idea of the scope of the problems. The front suspension bushings are ALL shot. The front left strut is done, and the rear struts are not so hot either. At some point in its life, it was in a minor accident, so the left fender, hood, and driver door need replaced. The check engine light has been on since I bought the car, and the OBDII checker O'Reilly's has can't read it. AND, the best part, lights in the dash randomly quit functioning. A third of the speedometer, and a third of the A/C control panel don't light up anymore. Which is only a minor neusance, but a problem nonetheless. It has an ebay open-air intake, which for $28 improved everything I could hope it would, and 17" 2003 Eclipse GTS rims.
    Overall, though, the car has been pretty good to me, and despite all of the issues, continues to pound pavement like a champ for my girlfriend until it's paid off in three months. I've replaced the starter already, and I'm handling any other issues that come my way as they approach, until I can really dump money into it to get the ball rolling, because this build involves swapping engines, so I need to keep this car running as long as possible. I'm considering buying another car for her to drive during this build, because it is probably going to take a while. But, on to pics, and at the bottom of the post, I'll put the to-do list.
    The day I got it:
    First day delivering pizza in it (I have since replaced the fuel door with one that is body color):
    After moving to the new house, with a yard and everything!
    (Not actually a house, that's the city building)
    To-do list:
    Full 2001 Eclipse GT Prothane polyeurethane bushing kit
    2001 Eclipse GT KYB AGX struts, with Eibach lowering springs
    2002 Diamante 3.5L DOHC V6, with a fresh stock rebuild and powdercoating.
    2000-2004 Eclipse V6 manual conversion (already have shifter assembly, need everything else)
    Custom exhaust from the cat back (very few aftermarket options available) with dual exits
    New stock radiator and hoses, with dual A/C fans instead of the wimpy stock setup.
    Hyundai XG350 intake manifold
    New OEM fender and door
    THIS not yet in production hood:
    <a href="http://www.thegalantcenter.org/showthread.php?52939-New-8g-bonnet-design-found-and-replicated"> New 8G hood </a>
    Full tint
    JDM pre-facelift VR4 front bumper and grille
    JDM pre-facelift VR4 sideskirts
    JDM pre-facelift VR4 rear bumper
    JDM pre-facelift VR4 headlights, correctly wired
    "Mailbox illuminator" hidden lights, used to identify addresses during pizza delivery at night
    JDM power folding mirrors
    Custom 3-gauge A-pillar pod (no aftermarket options available, in progress)
    Full black interior conversion
    2004 Eclipse GTS black leather front seats
    Blue LED interior light conversion
    JDM folding rear seats
    New dash (possibly looking into modding 3/S dash to fit)
    Center console on-board computer with navigation "always online" mobile internet
    3000GT VR4 brake conversion
    Diamante rear seat reading lights (acquired)
    Flashed ECU, to handle 3.5L 5spd and minor mods
    Galant GTZ sway bars
    Evo 8 steering wheel and shift knob
    Ralliart Evo 8 pedals
    Superwhite LED dome lights
    Black/blue metalflake paint
    Remove rusted underbody parts, repair underbody rust, coat underbody in spray-on bedliner, powdercoat and install new/refurbished underbody parts
    Still don't really know exactly what I want out of the TT, with the exception of a somewhat reliable 500hp, and as little weight as is reasonable. It's going to be 3000GT body converted, with the exception of the R/T sail panels, and Stealth wing. At least one of the turbos are completely dead, and the transfer case has exploded, so it definitely needs those, but I plan on building and upgrading everything.
    But here, have some pictures of it in the mean time.
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Subbed
    First two posts updated with pics and lists.
    Okay, I promise I'll get the TT post updated as soon as I figure out exactly what I'm doing with it...
    Unfortunately, that's pretty hard to figure it out.
    For now, though, enjoy two posts full of pictures, following this post!
    As referenced in the Galant's post above, I'm making a custom gauge pod pillar, because there isn't one available anywhere for the LHD 8th Gen Galant. Prior to this, I've never worked with bondo, so it's a pretty new experience for me. It's interesting to work with, and seems like it's going to work pretty well in the long run.
    I started off with a generic ebay triple gauge pod, and a factory a-pillar cover:
    The pod has ribs on the inside, which make it more difficult to fit to the pillar, so I had to grind them down.
    Fitted up to the pillar:
    Lines marked to see where it needs to line up for installation, and holes marked for drilling:
    Bondo!
    So, I've made a little progress on it, but it's nowhere near done. Depending on what happens, I may actually finish it some time this summer. It's just so time-consuming and a drain on my focus that I can only do it when I have time and I feel like I can do it.
    Also, I started doing the robo-mod on the SOHC, but in the process I broke one of my halos, so I have to wait for more to show up from Chinaland.
    But I got one completely finished. Have some pics.
    A couple pics, since some stuff has gotten done:
    Snagged a great set of 8GB Galant headlights at the junkyard, and they're a lot better looking than the 8GA headlights, so we swapped those out:
    Rolled 178k in the Stealth:
    Finally finished the robo mods!
    Also got around to getting the headliner recovered. Had my lovely girlfriend do it, since it's her car!
    Also gave her a good wax!
