Results 1 to 10 of 23
Thread: Boat Restoration Project
    Andover, MN
    Sooo... this is a much different build than everyone is used to. No car here... Yes, it's a boat project. Here's the scoop:
    Monday was my mom's boyfriend's birthday and she wanted to buy him a project boat, nothing insane, but something we can all go out on and enjoy and do some fishing here since we are on the lake. Originally we were just looking for a trailer because my mom's boyfriend had a 12 foot boat already but it didn't have a trailer. So we were looking around and we found a boat fairly close with a trailer, lifetime trailer registration, and boat up to date on registration, but my mom was not willing to spend what the ad wanted for the boat which was $900. So I told her, email the guy and offer your maximum expense that you want on the boat and see what happens, so she offered $500. The guy responded back with $650 so we took it. Went out to pick it up.
    The boat is a 1979 Glastron Sportster Tri-Hull with an 85 horsepower Johnson Outboard. The boat has rotted floor, upholstery was shot, needs new seats, and the motor needs a few tweaks to get going. We pulled it home and the trailer tires were dry rotted and pieces of the tread were coming off. We made it home without blowing the tire up and parked it. While I was downtown for some job interviews, my mom and the boyfriend went to town on the boat. My mom cut the floor out and made an oopsie and cut the hull (I told her to use my roto zip to cut the floor out instead of the big ass circular saw.) So I have been put in charge of rewiring the boat and polishing the boat throughout. My mom's boyfriend is going to get the outboard going, which he was able to get going, however, he thinks the starter is having issues and needs some work first. The outboard was completely rebuilt at some point because it has evidence of a socket being on the bolts.
    I polished the boat today on the exterior and got rid of most of the staining over the years, but to really do a good job it would require some sandpaper and a repaint, so we are going to leave it. The stains are barely visible. I pulled the railings off on the bow section and pulled the front light assembly off. The seal for the front light is in good shape, but the bulb needs to be replaced.
    More pics to come....
    Boats Pics required!
    Nice. I'm involved in a boat project right now too. I was going to start a thread, but figured I would wait until it's all done. If you do decide to paint it, I"m having very good luck with Interlux products. I have their 2 part epoxy primer which sand really easy, and their brightside gloss paint which lays down really flat and has a nice shine to it.
    Andover, MN
    Quote Originally Posted by fastfalcon94 View Post
    Nice I will have my mom check it out as she will probably be doing the painting.
    Player Hater of the Year
    San Antonio, TX
    The floor was rotten but the stringers were good?
    Andover, MN
    Quote Originally Posted by Turbo Beast View Post
    The joists supporting the floor need some work too, We are going to cut some slots in the joists and run more solid wood planks perpendicular to the existing joists. To re-run the joists would be quite a bit of work as most of the boat would need to be stripped out.
    Andover, MN
    Ok here's an update. First of all, I don't have any pics YET. But I will get some pics.
    Here's what we have so far:
    - New Boat seats from a small Wholesaler locally. Picked up light blue lounge seats x 2 for 130 each which has plastic frames instead of wood frames (BIG PLUS)
    - New 3/4 inch pressure treated flooring sheets of plywood. This should be more than sufficient for our needs as this boat is on a budget and we are going to most likely do a spray on bedliner to coat the surface prior to putting the carpeting on.
    - New marine carpeting that is the typical blue.
    - New upholstery that my mom and her boyfriend picked out. It's a crazy zebra looking blue and white pattern. The reupholster is for the accent boards around the perimeter of the boat, the next thing to pick up is the foam for the reupholster.
    - Not necessarily marine grade, but, Sony Xplod head unit with 4 channel and 1 pre-amp out. Also, we have 4 speakers to mount in the boat that are not marine grade, but not a big deal.
    - New rear light post.
    - New light bulbs for front light
    I ran a couple tests on the ignition switch in the Johnson control center and found that the switch appears to be fine, we might have an issue with the neutral safety switch. I did test the neutral safety switch continuity and it looked good so we're going to try it out. I am suspecting that the wiring from the outboard to the battery needs replacement as it is older and probably has corrosion behind the insulation, the wiring from the control center to the outboard is very clean and solid. The boat came with a fuel pump rebuild kit for the outboard which we have already rebuilt the fuel pump and we tested the starter and the starter is working perfectly normal. Tomorrow is going to be a test day and then I am going to be running the wiring for the speakers, amplifier, and re-running the wiring for the head unit and getting it all tested and running. I am also probably going to wire in the antenna wire for the marine CB radio so we can have that for safety even though we are not going to be taking this boat on very large lakes.
    Pics will follow tomorrow.
    Good progress
    Andover, MN
    Here we GO!
    Pics as promised:
    It's a pretty nice boat, can't complain too much.
    So here's some more stuff:
    Here's the flooring taken out as it was rotting:
    Seats and marine upholstery:
    Carpet:
    That's all for now. I finished the wiring for the stereo and speakers. We are also going to put a subwoofer in under the stereo... It wasn't my idea, my mom wants a subwoofer installed, so I need to run the power wire from the battery to the front once the floor is installed. I am sorting out the wire for the remote power on for the head unit. The head unit has a remote amp turn on wire as well as 1 set of pre-amp outs. I found a wiring diagram:
    I am going to be using the violet wire for the On Position for turning on the head unit and amplifier. That way in the event the stereo is left on, the key turned to off turns the head unit and amplifier off.
    YOUUSSS TRROOOLLLIN supporter
    Boston, MA
    subbed. boats are awesome.
    -jeff
    1992 SVX LS-L
    1996 3000GT FWD-TT
    2005 XC90 T6 AWD
    i collect parts.
