a while back someone posted a thread showing
how to remove the shifter front the tranny and lightly modding it for a smother shift
i cant seem to find it
anyone know what im taking about??
kx
kx
someone smoothed the rectangular piece inside the shifter assembly (in the trans) and said that it made for smoother shifts.
sounds interesting. anyone have a link?
I have a really notchy shift. I always though it was due to my Ralliart short shifter but since I never drove with a stock shifter it was always just an assumption. Since I have the trans apart right now replacing the output shaft I will have to check out the bolt Toni mentioned and try David's fix to see it it helps it at all.
I'll have to give that a try sometime.
I took a look at this last night. As I posted in the thread I just don't see how this would help. I even put together my spare case to get an idea of what's going on. My cage didn't even touch those corners until it would have stopped at the reverse lockout cam. Maybe I am missing something or perhaps this only helps when the cage is worn and loose. Mine was solid and had little to no play.
Hard to argue with some of the results people are seeing though![]()
2013 January Car of the Month - All 3s
2011 November Car of the Month - Interior
If my links/photos don't work replace penguinhosting.net/~bigmac with primaryboost.com
Uncut 3000GT keys for sale! Various colors!
FWIW I had way better results just replacing the selector assembly inside the trans than I did messing with anything else. Right behind that mod, I'd say to use solid washers to mount the cable bracketry on the trans. The shifter base bushings in the center console also made a nice difference, but mine were really worn out.
