So I finally got around to installing my PNP flash ECU with Chrome V2, and I have 2 problems.
When no lift to shift is enabled there is an RPM limit of 6500. I don't see a setting set to 6500 rpm. The rpm limit that I do see is set to the stock rpm of 7200.
Also, when the CEL on knock feature is enabled, I get random fault codes being thrown.
Launch control and fuel pump on clutch both work great.
Any thoughts?
