Results 11 to 20 of 44
Thread: Not Running Right After Evo Injector Install
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Alright I pulled the code - just a random misfire. I was hoping it would say injector 4 was out and cross my fingers that it somehow got unplugged.
    Any ideas other than pulling it apart and checking everything? I wish I could run the car with the plenum off lol
    What is the history of the injectors?
    ~2006
    I bought them off Evotuner on 3Si. Said he cleaned and flow tested them. According to the sheet he gave me all the resistances are +/- 0.1 and they all flow 600CC +/- 1CC. I was going to double check the resistances myself but got lazy and didn't.
    I lack color... verified
    Aug 1998
    I doubt your injectors are the problem.
    ~2006
    Why do you say that? I doubt they are as well, just wanted to see your reasoning.
    Do you know which injector number 4 is?
    If I can take some time off this weekend I'll probably check the continuity of the rear bank wires (if that includes #4) from the plug to the bigger plug that bolts to the plenum as well as ensuring that they are actually plugged into the injectors correctly. If that stuff is all good then I'll probably switch a few injectors around and go from there.
    I'm guessing I can't apply 12V to the injector as a crude way of testing them, right? Would be cool if I could leave them on the rail and jump the fuel pump to make sure they are spraying.
    yes you can, but most places recommend using a 9volt battery for safety. It is unlikely evotuner sent bad injectors, those were the same ones I was running.
    It is some work, but if it were me I'd put the stock injectors back in with the stock settings and see if the problem goes away. That should eliminate wiring or some other issue as a problem.
    Aug 1998
    Experience.
    See it all the time. Guys replace their injectors but not the rubber insulators which seal the injector to the lower intake plenum. I bet if you did a pressure test, you'll find the seal for injector #4 (center rear cylinder) is leaking.
    Guys running piggy back can get away with this intake leak because they just adjust the airflow signal for it. Flash ECU is a bit more precise than that.
  8. The Following User Says Thank You to Greg E For This Useful Post:
  9. #18
    Aug 1998
    EVO injectors are denso injectors like ours but the sealing surface of the injector heads are slightly different size than ours. I bet you every single car out there with "bad EVO injectors" are the result of this seal leaking.
  10. #19
    ~2006
    Dude! I test fitted the insulator on the evo injector and I thought it fit looser than on the stock ones! I thought it was my imagination/it would go away when they were torqued down. Is there a solution if that is the problem? All the insulators fit the same so its not like there was a bad seal.
  11. #20
    Aug 1998
    If you buy NEW OEM ones, they will seal perfectly again.
  • History
  • Information
  • Groups
  • Events
  • Resources
