Well I finally got around to installing my Evo 560s today. Everything was going smoothly for once until I fired it up after the install.
Sounded like a truck at first with 600CC (what the injectors actually flowed) and latencies off the EvoM board. Then tried the latencies from this board and it got a little better. Then put 560CC and got a little better but still doesn't sound right. Wideband says it is running ~16:1 at idle. If I rev it it sputters as the revs rise but if I hold the RPMs steady is sounds about the same as idle. When I let off it will read 12:1 for a second.
Trims are ~120 low and mid (can't remember exactly) and 100 high. They were about 120/110/100 before the install (didn't reset the computer). The O2 trim fluctuates from 100 to 120.
CEL came on after a while but when I tried to read it is says speed sensor.. I am not real familiar with Evoscan though so maybe I picked the wrong setting? Evoscan 2.9 and Chrome V2.
When I disabled injectors they all made an impact (which varied from injector to injector) except #4. Please tell me this is the middle one on the rear bank lol
I don't see any leaks on the front bank and don't smell any fuel. New O-rings and insulators. Put the retaining clips back in the plugs as well as the metal thing that holds them on the rail.
Fuel pressure is good.
Only things I can think of are:
1. Messed up flash ECU settings (all I changed was injector size and latencies).
2. Messed up wiring - the wires sound pretty crispy when I was doing the install. I tried wiggling what I could reach and it didn't change anything though.
3. Forgot to plug something back in/put something back on - I followed the stealth316 tutorial if you are wondering what I removed.
4. Vacuum leak - I did use a new plenum gasket though.
What should I do? Any ideas?
Should I put the stock ones back in (rule out electrical), rearrange the Evo injectors (isolate the problem to one injector), remove plenum and cut back the sheath on the wiring to inspect it/run continuity test, something else? I don't have a compressor here or I would pressure test. Any other ideas? I am busy with school (this past weekend I had some time off) so whatever is the most time efficient is the ticket for me.
Thank you!
