Results 1 to 6 of 6
Thread: WTB: non-working PS window regulator/track thing
    A constant work in progress.
    Erie, PA
    My motor still works, but that shitty plastic guide piece at the top of the track broke in half. Therefore, I don't want to pay $9000 for a working one, but more like $20 for a non-working one that has a good track/white plastic thing. I'm sure there's a lot of them out there that people have sitting in their garages, so let me know. Passenger side.
    1995 3000GT VR4 - pearl yellow 1 of 42 - race car!
    1992 Stealth ES - saved from the junkyard - community loaner car
    1996 3000GT base - purchased 2006 - WRECKED/PARTED
    1991 3000GT VR4 - rusty POS Edition - SOLD
    Medford OR
    They all fail just like yours did... I don't think I've ever seen a motor go bad on an otherwise working regulator.
    You're hunting unicorns...
    Sep 2012
    Decatur, TN
    Pretty much this. I believe someone one the other forum for a while sold them after tacking in sheet metal to reinforce the plastic.
    I can check, I MAY have one here. I'll check tomorrow morning.
    Erie, PA
    Hmm. When I always saw people bitching about needing new ones, I assumed the motor killed itself. So people are essentially paying $100 for a little piece of plastic that broke off?
    St.Louis
    Nothing will work as well as a factory new regulator. I got one (insurance monies) after my car got broken into and it goes up and down soo much faster than my pass side "new used" one does. I also fix mine by riveting a SS plate to the back of the plastic/rail assy.
    Quote Originally Posted by alexw3000gt View Post
    Yup. Every regulator I have ever had in my part outs has either worked perfect, or the plastic was broken.
