Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: How the hell...
    Too Many Cars
    Aug 2012
    Such WOW
    MD & DE
    I would first get the battery back up to charge, and reconnect to see what is exactly going on.
    Roger that. I had planned on letting it trickle for a bit, but if that's not the case, any possible plan b from folks who are more adept with the wiring scenario's could spare me an otherwise possibly wasted weekend. Got to love getting tied up loading trailers for your family all weekend when you wanted to wrench... thanks Coop.
    1993 3000GT VR-4 Purchased 1/20/12
    1990 Nissan 300ZX Twin Turbo Purchased 6/15/13
    2003 SVT Cobra Terminator Purchased 10/01/2013 - 1 of 23 Sonic Blue / Parchment Suede Coupes
    Canaan NH
    Crank sensor took a shit
    Too Many Cars
    Aug 2012
    Such WOW
    MD & DE
    I'll have to test that as well, thanks Corey.
    Twin Turbo verified
    Melbourne, Australia
    Hood or heat shield touching negative terminal.
    Sent from my GT-I9300 using Tapatalk 2
    Waiting install
    Build Thread
    Too Many Cars
    Aug 2012
    Such WOW
    MD & DE
    No fire blanket under this hood, and the hood was propped while cranking/re-connecting. I'll have to definitely test the battery, and take all of this into consideration. Thanks Joe.
    Andover, MN
    Ignition fuse under the dash and the Fusible link under the hood is popped
    You want to use IGN ACC wire for the LCD + and ground the LCD negative. I had the same problem with my electronic gauges it freaked me out and I thought the car jumped time/CAS went bad and it was fine. Check there first. I also recommend soldering all of your wires and heat shrinking the soldered joints do not use quick taps/splices as they don't hold and cause problems.
  7. The Following User Says Thank You to Boost4VR4 For This Useful Post:
  8. #17
    Too Many Cars
    Aug 2012
    Such WOW
    MD & DE
    Quote Originally Posted by Boost4VR4 View Post
    Ah! I didn't heat shrink... and I even bought a decent amount of it to do so. This sounds to be most on-par, as clearly you already went through the ringer on it. I really appreciate it, I look forward to seeing if this takes care of it. It's worth just combing through the whole thing again for the sake of posterity.
  9. #18
    Too Many Cars
    Aug 2012
    Such WOW
    MD & DE
    I got all of...5 minutes to mess with it this weekend! I pulled a "Grandma's Boy" and burned my hand off on a 400 degree pan (was slipping from the mitt, instinictively tried to save it... yeah, genius.) Anywho, I Did what I could with one hand, disconnected the battery and it is just fine. I removed the starter relay, reconnected the battery, reinstalled the relay, and it started up fine, but now it seems to hunt ever so slightly with a low idle. Any form of a boost leak or what-have-you is impossible, as the car hasn't moved a foot since it went awry on me with tripping the relay. Any idea on what to check now? I'm getting down to my last nerve with this car, clarity is not with me or my burned hand.
