I searched, and the information was pretty scattered. I thought it would be helpful to post all of the information in one place for people in the future.
Goal: Use a 99 Clone ECU in a 91 RT/TT.
What is needed:
-A 99 Clone ECU
-Adapter harness to connect your 91 vehicle side plugs to the 99 ECU interface
-Fan control - First gen radiator fans are controlled by temp switches at the bottom of the radiator, independent of the ECU. The 99 ECU controls the fans, so a harness to connect to the stock fans is needed
-Manifold Air Pressure (MAP), this sensor doesn't exist on first gen cars but the 99 ECU is not expecting a signal. No change required.
-Cam vs crank angle sensors. The 91 uses a cam angle sensor while a 99 uses a cam and crank angle sensor. No adjustment is needed as far as the ECU is concerned.
Please feel free to chime in. This isn't intended to be perfect on the first pass, and I will edit this post as more information flows into the thread.
