Results 1 to 6 of 6
Thread: Tactrix data logging
    Hopewell Junction, NY
    having a problem logging with the evoscan it randomly
    disconnects and is really starting to piss me off lol
    has anyone put together a proper LOGCFG File for the tactric cable so we can log with that?
    i have one loaded in the cable but some thing just done look right :/
    is this correct and is there anything else i should have
    Code:
    ; sample logging configuration file for openport 2.0
    ; must be named logcfg.txt and be placed in the root directory of the
    ; microSD card inserted in the openport in order to work
    ; this sample logs using the MUT-II protocol over the K-line, which works
    ; for many mitsubishis, including the EVO 8 and 9
    ;----------------mut2----------------
    type=mut2
    ; you can also set an OBD pin to a voltage, ground, or a high impedance state
    ; the first number is the OBD pin number, the second number is the pin voltage with the following values:
    ; 8000-18000 : voltage in millivolts for OP2 Rev C and earlier
    ; 5000-25000 : voltage in millivolts for OP2 Rev D and later
    ; -1 : set pin to high impedance (default state)
    ; -2 : pull pin to ground
    ; keep in mind that if you are applying a non-zero voltage to more than one pin, all of those voltages
    ; must be the same
    ; the following setpinvoltage sets OBD pin 1 to ground, which is needed to enable logging on older Mitsubishis
    ; it is commented out as it is not needed for newer models (e.g. EVO 8/9)
    setpinvoltage=1,-2
    paramname=TPS
    paramid=0x17
    scalingrpn=x,0.39215686,*
    paramname=RPM
    paramid=0x21
    scalingrpn=x,31.25,*
    conditionrpn = TPS,10,>
    action = start
    conditionrpn = RPM,7000,>
    action = stop
    paramname=KnockSum
    paramid=0x26
    paramname=TimingAdv
    paramid=0x06
    scalingrpn=x,20,-
    paramname=InjPulseWidth
    paramid=0x29
    scalingrpn=x,0.256,*
    paramname=AEMUEGO
    paramid=0x39
    scalingrpn=0.03913,x,*,10,+
    paramname=2ByteLoadRAW02
    paramid=0x02
    paramname=2ByteLoadRAW03
    paramid=0x03
    paramname=FFUELTRIMLOW
    paramid=0x0C
    scalingrpn=0.1961,x,*,-25,+
    paramname=FFUELTRIMMID
    paramid=0x0D
    paramname=FFUELTRIMHIGH
    paramid=0x0E
    paramname=FSTFT
    paramid=0x0F
    paramname=RFUELTRIMLOW
    paramid=0x4C
    paramname=RFUELTRIMMID
    paramid=0x4D
    paramname=RFUELTRIMHIGH
    paramid=0x4E
    paramname=PrimaryO2Front
    paramid=0x13
    scalingrpn=0.01952,x,*
    paramname=PrimaryO2Rear
    paramid=0x3E
    Kx
    Member
    Arvada, CO
    Just for reference here is mine. im not logging 2byte load right now since I know Im not going over 160 load just yet. I need to get the coolant temp working properly though, right now its showing low 80s at full operating temp.
    type=mut2
    ; must be the same
    setpinvoltage=1,-2
    paramname=TimingAdv
    paramid=0x06
    scalingrpn=x,20,-
    paramname=RPM
    paramid=0x21
    paramname=TPS
    paramid=0x17
    paramname=Airflow
    paramid=0x1A
    scalingrpn=x,6.25,*
    paramname=2ByteECULoad
    paramid=0x1C
    scalingrpn=x,0.625,*
    paramname=KnockSum
    paramid=0x26
    priority=2
    paramname=InjPulseWidthRear
    paramid=0x29
    paramname=InjPulseWidthFront
    paramid=0x2B
    paramname=Speed
    paramid=0x2F
    scalingrpn=x,1.242742384,*
    paramname=RearFuelTrim_Low
    paramid=0x0C
    scalingrpn=x,0.19607843,*,25,-
    priority=2
    paramname=RearFuelTrim_Middle
    paramid=0x0D
    priority=2
    paramname=RearFuelTrim_High
    paramid=0x0E
    priority=2
    paramname=RearO2FeedbackTrim
    paramid=0x0F
    priority=2
    paramname=RearO2Sensor
    paramid=0x13
    scalingrpn=x,0.0195,*
    paramname=FrontFuelTrim_Low
    paramid=0x4C
    priority=2
    paramname=FrontFuelTrim_Middle
    paramid=0x4D
    priority=2
    paramname=FrontFuelTrim_High
    paramid=0x4E
    priority=2
    paramname=FrontO2FeedbackTrim
    paramid=0x4F
    priority=2
    paramname=FrontO2Sensor
    paramid=0x3E
    paramname=Battery
    paramid=0x14
    scalingrpn=x,0.0733,*
    priority=2
    paramname=ISCSteps
    paramid=0x16
    paramname=AFRMAP
    scalingrpn=0.11484375,x,/
    paramid=0x32
    paramname=CoolantTemp
    paramid=0x07
    scalingrpn=x,1.593,*,38,+
    priority=2
    paramname=AirTemp
    paramid=0x3A
    scalingrpn=x,1.8,*,38+
    priority=2
    paramname=KnockBase
    paramid=0x6B
    priority=2
    paramname=OCTNumber
    paramid=0x27
    priority=2
    paramname=WGDC
    paramid=0x86
    conditionrpn=RPM,100,>
    action=start
    conditionrpn=RPM,0,==
    action=stop
    I lack color... verified
    Aug 1998
    I'm getting rid of the 2 byte stuff in the next version of chrome. Should make logging simpler for you guys!
    Member
    Arvada, CO
    it will be awesome to be able to plug the tactrix in and log whenever you want to and see the higher load and airflow values.
    also for anybody with a first gen that is looking for ideas on where to mount the OBD2 port for convenient access, this is what I did. It allows me to easily plug in the tactrix while stopped and keep it and any wires out of the way towards the passenger side when using the laptop (to flash or with evoscan). of course this only works if you have the single DIN pocket.
    Aug 1998
    Looks great! Most creative install I've seen!
    Member
    Arvada, CO
    I made a few changes to my logcfg file. got 2byte load and airflow working so what shows up in the csv file is just the full 2byte stuff. also added a tps condition so i can switch between logging any time the car is running or just when the throttle goes over 75% just by uncommenting one set and commenting the other. I still havent been able to get the coolant and air temps to read properly. the equations work fine in evoscan but its coming up with something different on the tactrix, so for now I just left them with no scaling.
    type=mut2
    ; must be the same
    setpinvoltage=1,-2
    paramname=TimingAdv
    paramid=0x06
    scalingrpn=x,20,-
    paramname=RPM
    paramid=0x21
    paramname=TPS
    paramid=0x17
    paramname=Air1
    paramid=0x00
    scalingrpn=x
    isvisible=0
    paramname=Air2
    paramid=0x01
    scalingrpn=x
    isvisible=0
    paramname=2ByteAirFlow
    scalingrpn=Air1,256,*,Air2,+,0.09828125,*
    paramname=Load1
    paramid=0x02
    scalingrpn=x
    isvisible=0
    paramname=Load2
    paramid=0x03
    scalingrpn=x
    isvisible=0
    paramname=2ByteLoad
    scalingrpn=Load1,256,*,Load2,+,0.3125,*
    paramname=KnockSum
    paramid=0x26
    priority=2
    paramid=0x29
    paramid=0x2B
    paramname=Speed
    paramid=0x2F
    paramid=0x0C
    priority=2
    paramid=0x0D
    priority=2
    paramid=0x0E
    priority=2
    paramid=0x13
    paramid=0x4C
    priority=2
    paramid=0x4D
    priority=2
    paramid=0x4E
    priority=2
    paramid=0x3E
    paramname=Battery
    paramid=0x14
    priority=2
    paramname=ISCSteps
    paramid=0x16
    paramname=AFRMAP
    scalingrpn=1881.6,x,/
    paramid=0x32
    paramid=0x07
    scalingrpn=x
    paramname=AirTemp
    paramid=0x3A
    scalingrpn=x
    paramname=KnockBase
    paramid=0x6B
    priority=2
    paramname=OCTNumber
    paramid=0x27
    priority=2
    paramname=WGDC
    paramid=0x86
    ;conditionrpn=RPM,100,>
    ;action=start
    ;conditionrpn=RPM,0,==
    ;action=stop
    conditionrpn=TPS,75,>
    action=start
    conditionrpn=TPS,75,<
    action=stop
