Pertinent mods:
6266 DBB .84 divided housing
PowerHouse Racing turbo kit - open manifold, single gate
4” dp/mp; Apexi N1 catback (necks down to 3” at the flange and then to 3.15”)
Turbosmart 50mm WG
GReddy 3-row
UR Cams gears at +1, -3.5 (previous BPU settings)
OBDII ECU; VPC/AFC NEO
AFPR on the stock FPR return line; base FP @ 45psi
TRD diff; 1-piece chromoly DS
ACT Turbo Xtreme clutch (full-faced organic disk); UR lightened FW
CCW Drag Pack w/ 26" ET streets
Mix of 100 and 110
Dyno:
560WHP at 18.5psi
545WHP at 18psi
525WHP at 17.5psi
The only changes I made following the dyno was I added a Fuelab AFPR off the stock FPR return line so I could bump the base FP up a bit. I did a little street testing and found that 45psi static is the sweet spot to maximize all the OEM fuel pump can offer. I tried 50psi and found that it leaned out earlier up top than at stock fuel pressure, so the pump is the limiting factor now.
On to the runs...
1st Pass -- My line lock button wigged out and didn't engage so I just did a quick spin to clean off the tires and went easy on the launch. I walked it out hole with rowed through the gears on an easy pass to check A/F and went 11.39 @ 129.7MPH. Boost peaked at about 18.5psi; A/F was good and never exceeded 11.8.
2nd Pass -- Bumped up the boost 2%. Did a nice smokey burnout to get some heat in the tires and left at 5000RPM (free-rev, no 2-step) with a quick slip. The car left hard and then the RPM's shot up so my instinct was to shift to keep off the limiter and when I banged into 2nd the car fell on its face for a second as the RPM's dropped down to 4000RPM -- turns out it was clutch slip and not tire spin...! Lazy shifts into 3rd and 4th and ended up with 11.0 @ 130.4MPH Damnit!! Boost peaked at a hair over 19psi and A/F touched 12.1 at the top of 3rd.
3rd Pass -- The track was hooking up nice and I still had 16psi in the tires so I did a shorter burnout and tried to get off the clutch a little quicker on the hit. The car left hard and like before once it hit about 6k the RPM's quickly shot up so I pedaled it this time and the clutch grabbed and then bogged a bit so I banged into 2nd and lazily hit 3 and 4 since the run was already killed. Ended up with 11.37 @ 130.2MPH with the best 60' of the day at 1.63. If only...
4th and 5th passes I tried different launch techniques to induce a little more wheelspin to keep the clutch happy but both passes resulted in being blocked out of 2nd gear. I had this issue last summer at BPU levels when I was trying to launch with the 2-step/Antilag box. The clutch heats up and blocks me out of 2nd. Being an organic disk once I put a hundred or so miles of more normal driving on it seems gets better, but either way it's not going to hold up to any more drag racing. I have an RPS C/C on the shelf that I was hoping I wouldn't need until I could turn it up on fuel, but looks like that's next on the agenda.![]()
Great power. Any billet twins you would recommend for my TD05 headers and future 3.5L?
