Results 1 to 10 of 19
Thread: Front crash bar- Is it really needed??
    Jun 2011
    Sweden, Gothenburg
    I mean for safety.
    Our cars has a long ass front with a big ass block. Probably way better crash safety than most cars even without the crash bar. I deleted min because I want to remove as much weight from the front of this car as possible since it's front heavy.
    https://www.youtube.com/watch?v=z6BVRxBhqqs
    Can't imagine the alu crash bar does that much difference.
    my dad pointed out for me that it's also there for stiffness. That's the only reason I could see it being worth saving it for.
    Opinions?
    Stiffness? They aren't even solid mounted to the frame rails. They are there because insurance companies have made the auto makers adopt the 5mph bumper system. It keeps damage to a minimum under 5mph. It is not a safety feature.
    Jun 2011
    Sweden, Gothenburg
    Quote Originally Posted by donniekak View Post
    good point. probably right that it's mostly for smaller impact to protect the body from damage.
    You sure about the stiffness thing though? it's mounted to the dampers which are bolted to the frame. Should keep the frame from twisting in my mind..
    yes /thread
    Quote Originally Posted by Tensecs2fame View Post
    yes /thread
    Excellent logic you used there.
    Advanced Tech? verified
    look at the design of the dampers, how the bolts are all inline (no triangulation). the crash bar provides NO chassis stiffening.
    The Panda Not Verified
    Washougal WA/Portland OR
    A thick front mount will work as a crash bar!
    Jun 2011
    Sweden, Gothenburg
    Quote Originally Posted by vr4tune View Post
    Banned J. Fast's Avatar
    - O - SIX -
    Colorado, USA
    Yes it is. It's a box girder resting on pins. In the event of a crash the frame rails act like springs. It couples them on frontal impact and also aids in preventing singular torsion on one corner. More than likely it also halves impact intrustion distance on the crumple zones at speed. If you hit a tree or pole at speed and you split the uprights how much further could the impact intrude?
    Ever seen lawdoggs hill climb crash where he hit a tree? He likely escaped rather serious injury due to the tortional resistance of the crash bar. The front end never twisted and the drivers side of the vehicle remained in-tact. The crashbar was able to redistribute some of the axial loads off the passenger side and transfer to the drivers side.
  10. The Following User Says Thank You to J. Fast For This Useful Post:
  11. #10
    Do NOT delete the front crash bar. If you ever hit something head on you are going to take away your first line of defense.
    Let me see if I can find pictures of a front crash bar from an accident on the 92RT that I 2g converted almost 10 years ago to show how it can help.
