So I am in the process of starting the rebuild on my stealth. I have the 3SX forged piston and rods. I know most of the time when connecting rods with pistons, you match the numbers on the rod with an orientation marking somewhere on the piston. With the 3SX ones, I see no marking. Is it because the piston is set up for a DOHC configuration and they are symetrical? If so, then how do you orient the rod markings in relation to the block? Thanks!
