I am in need of a lot of parts for my build and since I am low on cash, I can offer a powder coating service as a trade for your parts. You pay shipping both ways for parts that you want powder coated. I will pay shipping for the part you are trading me.
If you have a part that is on the list below, and you would like to have something powder coated, just contact me. Just try to be reasonable I won't powder coat 4 wheels if you are trading a me a $10 part without cash being added on your end. I can add cash on my end as well if you want something small powder coated in return for a more expensive part.
I can rebuild whole assemblies and clean everything up like new or you can break down parts and just send me what you want coated. I have a 5 stage prep process including sandblasting all parts. Areas that need masked will be. I will not blast anything that touches the engine oil(valve covers, oil pan, ect). I will still coat these parts, but they will be roughened up by hand instead of sandblasting.
I have several colors in stock:
HIGH GLOSS BLACK
BLACK CHROME + CLEAR ( Has a titanium look)
MATTE BLACK
SILVER
HIGH GLOSS RED
HIGH GLOSS CLEAR
SEMI GLOSS CLEAR
Examples of work:
Black Chrome:
Masking
Gloss Black:
COLORS WILL BE CONTINUED IN NEXT POST
PARTS I AM INTERESTED IN:
UNDERCAR:
AWS Delete Kit
Front Tie Rod Ends (New only, prefer oem)
Front ball Joints (New only)
Steering Rack Boots (New OEM only)
Driver side front CV Axle (prefer new)
Stainless Steel Brake lines (Turbo, silver or black)
2nd gen Rear VR4 Brake Calipers
2nd Gen Rotor (Blanks) ( need front and rear- good condition)
Slave Cylinder (TT) (Prefer New oem)
Water Pump (new oem only)
Crank Pulley 92+ (near new)
Passenger window regulator (working condition, non broken, needs to fit 95)
Interior Center AC Vent Assembly (good condition)
99 Underbody Plastic and lip
Skillard fuel line Sheild
Lowering Springs
ENGINE BAY:
Valve Cover Gaskets (New oem only)
OEM oil Pick up tube
Thermostat (new oem only)
Stainless Steel clutch Line (stm is the only one I know)
AC Compressor r134a, 4 bolt in good working condition
Hood Release Cable (good condition, not broken)
Setrab oil cooler
Oil Cooler Lines - Prefer Black braided with black or silver fittings (no ss)
Fuel Rail Loop (black fittings)
Aftermarket fuel lines(prefer black fittings and lines over ss)
HKS / FORGE / TIAL Recirculating BOV (authentic only)
Polished Intake Plenum
Polished Throttle Body (Preferred April Rebuilt)
Starter(Near New)
Aluminum td04 Intake pipes
NA Power Steering Reservoir (good condition)
Transfer Case Bracket (nelson or newer Maximal)
Subframe/control arm bushings (new only)
Any td04 upgraded turbos in good condition
Pampena Transmission Bracket
Walbro 400 or Aeromotive Stealth Fuel pump
INTERIOR and ELECTRONICS:
2nd Gen Dash(if your local to Central Florida)
Guages - Boost, oil pres, water temp(60mm defi, aem, Stack)
Blackstealth LCD Boost Controller
Flash ecu
TT Speedo Cluster
Dash Vents (non broken)
AEM Wideband
EXTERIOR:
Driver Side side skirt (good condition, preferably black)
99 Passenger side Turn signal (good condition)
Aluminum Rear Crash Bar
List will be updated when I think of more parts.
