Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 101 to 110 of 115
Thread: 3.5 DR750 build
  1. #101
    Delaware
    Pressure still stuck high. Anything we're missing other than the obvious fuel return line limit? Might buy some bigger line to run off the afpr and bypass the stock return just for diagnostic purposes.
    Jason
  2. #102
    One fix at a time verified
    Kansas
    Which AFPR are you using and are you sure there isn't too small of an orfice installed in it?
  3. #103
    return line plugged?
    run a line into a fuel can from the return port......does it drop back down?
  4. #104
    Forum User supporter
    Bounemouth, UK
    The usual fix is to run a bigger feed and then use the old feed as a return. or alternatively if you are thinking of doing the rear steer delete use the lines from the front to the rear rack they are quite large bore and steel
  5. #105
    Delaware
    Got the pressure sorted out. Had the smallest orifice in the regulator, put in the big one, 45psi base now.
    Still knocks at 5k-5500 like a fukin whore. Arc is maxed out. Need my compressor from work, boost leak suspected. If not, bonfire.
    Jason
  6. #106
    1993 rt/tt Not Verified
    wa state
    ...boost leak suspected. If not, bonfire.
    lol...saved for future use
  7. #107
    alamogordo, nm
    Jason
    Is the fuel pressure correctly matching 1 to 1 with boost? IE 45psi base, 55psi at 10 psi of boost, 60psi at 15psi of boost ect?
    When you say ARC-2 is "maxed out" what do you mean?
    93 RT TT 8.74@168.5mph @3600ft Worlds Quickest and Fastest 3000gt/stealth
    2001 Dodge Viper GTS Heads/cam/Paxton 873 rwhp & 803 rwtq
    95 RT TT 604 awhp 611 awtq (DR750's, and stock motor)
    2004 F350 Harley 14.4@90mph at 3600ft
    04 Lambo Gallardo (sold)
    95 3000GT VR-4 10.56@136mph- 714 AWHP & 607 AWTQ (dr-900's) (sold)
    92 Stealth RT TT 10.69@133.45mph @3600ft (dr-800's) (sold)
    95 RT TT 10.88@129.1mph @3600ft (sold)
    There are 2 ways to make a car fast.
    #1 use the Right combo of parts
    #2 Throw so much money at it that the car has no choice but to be fast.
    I choose #1
    Click for US 3S Fastest ET list
    Better to be a racer for a moment then a spectator for a lifetime
    "Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education alone will not; the world is full of educated derelict."— John Calvin Coolidge
  8. #108
    Delaware
    Yes, working 1:1 now. Cant find a balance between high/low. We have the high maxed out and not enough fuel up top, still leans out in the middle since to keep the idle at all, needs the low fairly lean, around zero or +1, accel at +3 i think and its not enough down low causing it to come up short up top. Cant seem to get it balanced to where it will idle, fuel enough down low but have enough fuel up top. We got a few clean pulls, but had so much fuel it wouldnt idle, at all. And was like 10:1 up top, probably looked like a diesel lol.
    Fixed all suspected leaks and will reassess tomorrow after any/all leaks fixed.
    Last time we had this problem with the ARC is was a leak. So we shall see. But even at 14psi it'll pull smooth/clean to 5k rpms nice flat AFR 11:1-3 and around 5k...gotta lift since it'll instantly/predictably jump into the teens on knock.
    Jason
  9. #109
    VR-3747 :D Not Verified
    Dayton Ohio
    i know there is a flashable sittin in the basement. just sayin...
    i dont get the bonfire reference?
  10. #110
    I lack color... verified
    Aug 1998
    Jason
    Pump gas sucks.
    Install the 98 ECU and set the injector scalings. Get a decent tune with the ARC. Tweak the timing with ECUFlash.
