Just putting it out there the build is complete and the car is officially running .. Be on the street tomorrow ..
I wanna give a really big "Thank You" to Monchrome and JasonY who put in alot of time over the last few days putting the engine together and getting the install done ..
What a sleeper
The new
Merkel built 6G72 3.5
DR Stage 3 heads ..pinned
Unorthodox Racing Cam gears
Fully built trans containing
Quadco output shaft
Quaffe front diff
Bellhousing brace
Broomfield Endcase
AEM fuel pressure gauge
Billet oil pump gears
Deleted atmosphere Tial for a recirc Tial
Basically replaced the entire old setup with brand new everything ..Deleted Meth injection ..
This week after a shake down and break in I am swapping the springs for Megans and dropping 255/40/18 KDW's on.. Swapping the 255 for a Walbro 400 .. Adding the Ooga horn.. and swapping in the overclocked ECU ..
Car will be run on pump gas or 100/104 unleaded which is readily available less than a mile away from the house ..
Merkel 6G72 3.5
DR Stage 3 Heads w/ High Rev Spring Kit .. Pampena pinned .. Stock Cams
DR Port and Polished lower plenum
DR Tial 750's w 18psi forge wastegates
DR Arc-2 92mm
Unorthodox Cam Gears
IPS 750hp Anodized Precision Core Frontmount and hard piping kit
Overclocked (8100 Rpm) ECU (Current) .. Chrome on the shelf
Southbend Stage 4FE clutch
Rps Lightweight Flywheel
Greddy Boost Controller
AEM Digital Gauges (oil- fuel -temp -boost- wideband)
99 Lifters
IPS Setrab 25 row Oil Cooler
PTE 680 injectors
KB Boost a pump (Installed but not in use)
HKS DLI
Walbro 400 fuel pump
AEM FP regulator
3SX fuel rail loop
Ninja Performance Black Nylon Fuel kit
IPS downpipe
Tial recirc BOV 11psi spring
Tein S-tech springs .. Swapping to Megan Coilovers anyday
Carbotech Rotors
Hawk Pads and Stainless brake lines
Pampena Bellhousing Brace
Quadco output shaft
Quaffe front diff
Bellhousing brace
Broomfield Endcase
Jack Hammer 7 quart oil pan
Billet Oil Pump Gears
Maximal Solid motor mounts front and rear
Maximal Performance Adjustable Control Arms
Ebay 4" Megan knockoff exhaust
Krank vents
Stock 18 Chromies w/ KDW 255/40ZR18's
1 Oooga horn![]()
