Results 1 to 10 of 11
Thread: What to replace when installing injectors?
    ~2006
    Pittsburgh, PA/Wheeling, WV
    I am going to try to get around to install my injectors next week and I am wondering what all I should replace while I am doing it. The injectors come with new O-rings and my plenum gasket is a few years old.
    Should I replace the plenum gasket? Should I replace the insulators?
    Trying to save money where I can but I don't want to have to make 18 different orders/pay for shipping a million times either. I am just going to try to place an order through 3SX for everything I need (depending on their shipping charges).
    The insulators are best to replace because they are a boost leak if they get dried out.
    I've got to the point where it is easier just to replace the plenum gasket each time. felpro's are like $8 from the parts stores. You certainly don't HAVE to, but I just don't have the plenum off as much as I used to.
    RTBOOST verified
    Florence, Wisconsin
    If I were you, I'd personally get all new injector insulators (MD087060) & the fuel injector sheets (MD614805). You said that the injectors already came with o-rings (#1465A188), so that should be all that you would need...If you order through Cherry Hill, prices are $4.71/ea for the sheets & $1.74/ea for the insulators (o-rings are $3.39/ea). If you use 3SE as the code at checkout, that should pretty much cover half or all of the S&H charges.
    Sent from the garage
    ~2006
    I'll probably just order one from Cherry Hill since I'm placing an order anyhow. I think I've only had the plenum off once or twice so probably worth it.
    As far as the insulators, I need 6 of each right? Thanks a lot, the part numbers are really helpful!
    RTBOOST verified
    Florence, Wisconsin
    Yes, you'll need 6 of each...I was able to just check out my past orders to get you those part #'s as I am eventually swapping my injectors out, too.
    Also, those prices are from a while ago, but I can't see them being too far off, if they've even changed at all.
    ~2006
    It ended up being $60 shipped (I forgot to put in the coupon code ) for 6 of each of the insulators and a plenum gasket.
    holy shit
    ~2006
    holy shit
    That is what I say everytime I buy something for this car
    Padawan garage troll Not Verified
    Newark, DE
    May try Rock auto
    Revel in your time
    91 AWD TT
    K&N FIPK, Precats gutted, Test Pipe, Blitz DSBC, Walbro 255, Vacuum reduction, SM3, MMCd, Krank Vents, 3SX Aluminum Crank Pulley, Aluminum 2PC DS, MAFT Pro (AFC mode atm).
    To do list: Need to check electronic timing, install FP hotwire, install PS poly MM, RUACAs, Setrab oil cooler, Dejon Y-pipe, 3.5 GM Mas, FIC 650ccs & 13Ts.
    Jun 2011
    Sweden, Gothenburg
    just do a visual inspection. all my 2 decade old gaskets on my car has been perfect.
  • History
  • Information
  • Groups
  • Events
  • Resources
