Jacks is perfectly capable, but we do them too. My guy has over 10 years experience rebuilding 3/S trannys and over 20 years in the business. check the Auto Velocity section:
http://www.3sgto.org/showthread.php?...ssion-rebuilds
I've heard good things... course I've heard good things about my transmissions too. Last one even survived an 18 year old kid learning how to drive a stick with it.
I just bolted the transmission I got back from Jacks today. I got the stage 1.1 with the taller 5th gear for my '93 FWD. Had 171k miles on it, and the 5th gear nut backed off, but I was having issues with reverse for a while, and I'm hoping to keep this car running for another 120k miles at least. It took about a month shipping it there and getting it back. He did send emails every so often on what was wrong with it and any extra work they needed to do. He helicoiled a couple of threads for a fee. It was sent out pretty filthy and came back looking really nice and clean. Even put some bits I forgot to take off back in the box. Not sure about mechanical condition, but I'll report back when I get my car back on the road. Still have a good list of things to fix on it before then. Here are some pics of what it looked like out of the box.
That does look pretty nice. Thanks for posting pics!
An update to this. I now have 15k miles on the transmission. I think I've only been driving it since March. My second gear syncro is gone. I can double clutch into second no problem, but if I coast/engine brake in second, it sounds like straight cut gears. First gear is starting to do the same now, and it feels like 3rd gear is starting to develop issues.
I'm going to email them today. The problem started to develop a couple thousand miles ago, but I just didn't have the time to look into it. Last night, I double checked everything I could as far as proper clutch operation, and I drained and refilled the fluid. My fluid level was spot on. Only about 100ml came out when I took the fill plug out, and the oil that was drained was pitch black and had that nice fine metal paste silver to it. My magnet didn't pick up any chunks though.
So now I just regret trying to do things right. Should have just tightened that nut by 5th gear and called it a day.
Considering how this is the 4th NEW part on this rebuild that has failed on me, I am not sure whether they screwed something up, or my bad luck struck again. Would have rather had another new head gasket fall apart on me.
If you only got 100ml out when you drained it then you have a hole in your bellhousing. You likely have teeth missing on the differential. Been there, done that. Lack of fluid is probably why you are having the shifting issues.
Ah, I misread. Carry on.
The 5th gear nut is an NA thing.
