Results 1 to 10 of 11
Thread: Fuel rail loop anodizing
    Our stock fuel rails are not anodized, correct? Then why are we worried about the fuel rail loops that are bare aluminum having problems with e85?
    Great question...
    The stock loops are not aluminum.
    VR-3747 :D Not Verified
    Dayton Ohio
    ^^agreed. i tried to bend mine, and there is no way aluminum is that strong.
    Yes, but you are missing his point. The fuel rails are, and are fine with e85, why not the aluminum loops that are sold?
    I don't understand why they wouldn't be?
    I remember about a year or so ago someone claiming that you need a stainless loop for compatibility with e85. Do not remember who, but may have been a vendor trying to market their version?
    Dayton Ohio
    oh, i see. maybe they are parts from an older mitsubishi that are just reused?
    also, back when the cars were made machining processes may not have been reliable or affordable enough to extrude aluminum in an effective manner like that.
    idk just throwin out ideas
    1993 rt/tt Not Verified
    wa state
    I didnt know we were worried...
    o Are hard aluminum fuel lines OK with E85?
    􏰀 Again, this is a part that we have had no issues with. Testing for 3 years has shown zero corrosion on the inside of 1⁄2” Russell aluminum line. Cutting used line open at bends and straight portions shows a “like new” surface inside. We expect that IF there is a leak in the line it would allow air and moisture into the line and it would show corrosion. Steel lines have not been an issue either, other than the fact that ethanol seems to clean up any sludge or residue left from gasoline which may clog fuel filters a time or two until it is all gone.
    http://www.horsepowerinnovations.com...le/view/17/81/
    Very well could have been. In all honestly, I think I've seen almost all E85 related "hurdles" proven false here recently. Stock fuel system being incompatible being the big one.
