Results 11 to 20 of 23
Thread: Windshield fogging
    Mine often gets a dirty grime sort of fog on the inside after sitting in the sun. Needs to be wiped of with a cloth. What the hell is this? I thought perhas there was a leak somewhere from the heater but there is no fluids leaking inside and no heating issues. Plus I haven't used my heater since I lived in Melbourne 18 months ago.
    +1 to this. What is this?
    Ft. Lauderdale, FL
    Pretty sure this is a by-product of whatever crazy material mitsubishi used for the interior. Probably the same reason all 3000gts/stealths smell the same. Sun hits the dash and causes it to out-gas something that fogs the windows. I suspect it could be cured with a dash cover.
    Well I certainly wouldn't waste my time with that RainX Anti-fog bullshit. I used it once and it lasted all of about half a day before it went right back to fogging like crazy in most places...
    I think I'll try some of that visor stuff that was mentioned earlier. This is a really bad problem during the fall/spring lol.
    The Panda Not Verified
    Washougal WA/Portland OR
    does your a/c work? If not that will be part of you problem, because the a/c will dehumidify the cabin air.
    Anchorage, AK
    Quote Originally Posted by RL7 View Post
    HHHAAA, I noticed that too, every single one I have been in has that 3000gt smell.
    Tirkrit,Iraq
    http://www.c-clearantifog.com/index....FTJj7Aod0ycgzg
    We use this in this in the military... best stuff
  7. #17
    I'm Kind Of A Big Deal
    use that rainx anti-fog stuff on the inside of the glass. And make sure your windshield is CLEAN on the inside. Clean it with windex.
  8. #18
    Fowlerville, MI
    Quote Originally Posted by vr4tune View Post
    The fog isn't ON the inside or out. Try wiping both sides off and it just stays there.
  9. #19
    Canaan NH
    Windshield separating ? If its not on the in or outside then it must be in the middle. Between the glass where the stretchy plastic crap is.
  10. #20
    Tirkrit,Iraq
    Time for a new windsheild you got moisture between the glass...
    93 vr4/87 Iroc-z
