It occurred to me that this wouldn't be very hard to setup.
DIY 3000GT Active Aero Rewire for Manual Operation « imclumzy?s Weblog
Picasa Web Albums - imclumzy
The only difference you would wire it so the dash switch will control power to the relays and the ECU will be the trigger for the relays.
Chrome mod Custom Pin 48 output gives the user the ability to activate the pin based off coolant temp, RPM and Load. I could very easily add speed as another input condition. In fact, I can take it one step further where you can enable/disable the inputs you want to trigger the pin, then set the min/max conditions. You can eveon have the ability to enable if you want a min and/or a max condition.
What do you guys think?
This pin could literally be used for anything. Not just AA. OBD1 purge solenoid operation, Meth injection, nitrous... Hell it can turn on a streaming word LED banner that says, "eat my shorts" if you want.
