Results 1 to 10 of 11
Thread: 94 VR4/TT Hybrid ECU (Fed-spec)
    San Francisco, CA
    Up for sale is a low-mile hybrid 94 turbo ECU, fed-spec. This is compatible with 94-95 turbo cars, and others with modification. No leaky caps (these aren't really known to leak like the first gens anyway).
    $100 shipped. Trades welcome.
    AEM s2 EMS | E316Gs | E85
    Canaan NH
    Looking at the pinouts between the 91 TT and the 94 TT I dont think it would be overly difficult to make this work in my 91 VR4. What does you mean by its a hybrid ECU.
    San Francisco, CA
    Yeah not hard. 94-95 ECUs are referred to as "hybrid" because they were in between OBD1 and OBDII, they use Mitsu's MUTII protocol. This used to make them hard to connect to but these days it's a non-issue and supported by EvoScan et al.
    Canaan NH
    Cool. If you still have it in a couple days I will take it, by Friday will not be an issue.
    Just want to chime in and say that a 94 TT ECU does not have the same pinouts as a 91-93 TT ECU, so unless you change your harness it won't work. The hybrid ecu has 4 connectors, where as the OBD1 ECU has 3.
    http://www.stealth316.com/2-ecu94.htm
    Anyways, that is a good deal!
    94 SL, 16 C7 Z51
    Canaan NH
    Yeah the 3 connectors from the 91 TT fit into 3 of the four sockets for the 94 TT. The fourth connector only hold a couple needed wires for the TT, the rest are NA and auto only. I would need to move a couple wires around but its worth it for a ECU I can afford at this time. Sure he will sell it by Friday anyways.
    San Francisco, CA
    -- sold! --
    Canaan NH
    I knew it wouldnt last till Friday
    TN
    Saved me a $100 lol... thanks to whoever bought it.
    Canaan NH
    It was me lol. Gonna put it in my 91 VR4. Plan on posting a how I did it thread.........If it works out
