Just a quick note to remind everyone that the garage contains a section for timeslips.
3000GT / Stealth / GTO Forum - VB Pro Garage
Make sure your entry is updated.
We should use this this year for NG to determine if someone should be Unlimited or not![]()
hasn't been back to the strip since it became AWD. 14.9 as fwd/tt isn't anything to write home about.
My 93 SL, on the left.
1993 3000GT SL
Mods: 95 front end, Robomodded Glass Headlights, VIS CF hood, Megan Racing Coilovers, relocated battery, short ram intake, VR4 Plenum, OBX LSD, OBX longtube headers, test pipe, 3SX underdrive crank pulley, Fidanza 9lb flywheel, Spec stage 3 clutch, solid lower engine mounts, 80a poly filled upper/trans mount, poly front sway bar bushings, Momo steering wheel, 3rd gen lifters, Konig 18" wheels, 4300k HIDs, gutted trunk, AC delete, PS delete, Cruise Control delete, ABS delete, SRS delete.. Plus other random stuff.
