Results 1 to 4 of 4
Thread: wot breaking up at 4k minor mods
    I have a 1996 VR4 and here is whats done to it
    3sx downpipe, test pipe, borla rear exhaust.
    Upgraded Taylor wires
    open air filter
    BOV set up like factory not open atmosphere
    forget which spark plugs but they are new good quality ones ( I will have to check and see which ones)
    gutted one pre cat so far haven't done the rear yet ( not sure if this is the cause of the problem )
    That's it under the hood.
    when I hit 4k it sputters then its fine. seems to do this through the first few gears. Don't have anywhere to test it any faster.
    Man vs 3/S verified
    Kingston, WA
    Did you check the gap for the plugs? Even a stock turbo car will sputter with .040" gap. Put them down to .030ish, should be good to go then.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
    ^^^ What he said ^^^
    I will double check the gap on the front ones 1st thanx
