Since last weekend my car seems to be idling a bit rougher. It's not rough-rough (still idles at 750 rpm), but there is more vibration. Once in a while the engine would even shake the whole car sitting at idle. My car used to be lexus-smooth and definitely did not do this before.
Also, the exhaust is now popping a lot more frequently. It is most noticable when I let off gas to shift. I know 3S exhausts gurgle and pop even in stock form but it definitely wasn't this much.
The car is a 97 vr4 with 70k miles. It is stock. Some things that may be relevant are:
1. Plugs are new NGK coppers with 400 miles on them. They were gapped at .375.
2. New OEM plug wires. Again only 400 miles on them.
3. New left and right OEM engine mounts with maybe 200 miles on them. Front is original but it was still good. No clue as to the condition of the rear mount.
4. Drivability has not been affected. It still revs smooth at part throttle and pulls strong at full throttle.
5. No CEL yet.
Any ideas? I am thinking PTU or coils. I found a slight leak on the vaccum hose that goes from the Y-pipe to the wastegate actuator but even after fixing the leak I still have the same problems. Any help would be appreciated.
