This is actually quite easy to tune! Well when you gut the MAF, quite literally more air goes around it. This means that each pulse stands for a greater airflow number. All you have to do is adjust the MAF Adder value for this extra air. Leave the MAF Scaling table alone.
To keep your injectors and fuel table accurate, you just need to adjust the MAF comp values. How much or little can be calculated easily with the fuel trims and a wide band.
Live tuning would be very helpful for this...![]()
