yeah if my trims were 12.5+ I'd add 10% to the latencies and go from there. It also depends on your mid trim and forgive me if I don't recall what that is. If the low is twice as positive as the mid then add half as much to the latencies and increase the injector scaling the other half since the idle is affected so much by the latencies. etc.
That is the issue with a setup where so much is not stock. Without experimentally derived latencies on a 3/s (the evos MAY be close) you are not sure what is really off.
In the end it doesn't really matter as long as you use some method to get those trims down.
Any idea what cbatters is up to these days?
