Page 16 of 27 FirstFirst ... 6141516171826 ... LastLast
Results 151 to 160 of 261
Thread: 3.75L Build thread
  1. #151
    I lack color... verified
    Aug 1998
    Yes. I always scale back warm up enrichment a LOT. Almost to the point where its disabled.
  2. #152
    VR-3747 :D Not Verified
    Dayton Ohio
    interesting. good to know, thanks!
  3. #153
    Aug 1998
    Do you have my phone number Nate? Something tells me an hour on the phone with a linked desktop will do you some wonders.
  4. The Following User Says Thank You to Greg E For This Useful Post:
  5. #154
    Dayton Ohio
    i do not, ill shoot you a pm
  6. #155
    I generally find when the car is really fighting me while tuning that there is something really wrong. For instance I had a random high idle again recently and I thought the ISC was bad or it was because of weather change, but it turns out my krank vent burst the stock pcv line, so I had a big vacuum leak.
  7. #156
    Aug 1998
    A lot of people really don't understand that if you have a mechanically perfect setup, the flash ECU is literally plug and play. That video I did of my 99 VR4 starting was literally the first time cranking that car since assembling it. All the changes done were shown on the video. There were absolutely no drivability issues at all.
  8. #157
    Yes, where you can get into trouble is when you start "tuning" around mechanical issues. It is a snowball from there.
  9. #158
    Dayton Ohio
    the problem that i face is, even with a mechanically perfect setup (which i fully admit mine isnt, but its close) i am still running an ecu that is not made for my engine... at all. technically there isnt an ecu made for my specific engine. i am fine with tuning around issues, however, its hard to distinguish between issues and just the fact that my engine has so many unknown variables when it comes to tuning on a flash ecu.
  10. #159
    Aug 1998
    The ECU will work fine. The base tune is setup for a small engine small turbo setup.
  11. #160
    Dayton Ohio
    yeah i dont underestimate it at all, i am just saying that there are a lot of factors that im up against that 99% of 3s owners probably wont deal with (although there is information to be taken from it that can be applied to the factory 3.0L's). between the extra displacement, the maf i am using, the turbos i have, the amount my heads flow, and the rpm i am going to spin it at there are just a very small amount, a handful, of people in the 3s world that will ever run their engine like that.
    i wouldnt have bought it and spent so much time on it if i didnt think it could work
