just looking for input on what could / should do next if anything
List of mods currently as the car sits (might have forgotten a few)
1993 Mitsubishi 3000GT VR4
Engine Mods:
Bottom End
Pampena Stage 3
billet oil gear
3SX Crank Pulley
Top End:
Merkel Built heads
+1 ferra valves
Ferra dual valve springs and retainers
3 angle valve job
272 cams
fidanza cam gears
port and polish
3G Lifters
head lift fix
Cooling Mods:
Koyo Radiator
Flex A Lite Fans
Samco Radiator Hoses
Stock temp T-Stat
Seattle Solid Mounts
3sx water housing
Turbo Mods:
Dr750's ported with forge wastegates (15psi)
Intake / Intercooling Mods:
DR 90mm Intake manifold
Q45 throttle body
DR Plenum Spacer
Remote IAC Block
K&N Air Filter
Evo Maf
Custom Intercooler piping
Precision Engineering 3.5" Front mount intercooler
Tial QR BOV (recirc)
Exhaust mods:
DN Performance Turbo Manifolds
DN Performance O2 Housings
Dynamic Racing Down Pipe
Test Pipe
DN Performance Exhaust
Suspension Mods:
BC BR Racing Suspension w/adj pillow ball mounts
ADJ Rear Control Arms
Fuel Mods:
Fuel Pump Hot wire Still needed
Walbro 400
Denso 660CC Injectors
Custom -6an Fuel system from the tank forward
EK2 Fuel Rails
AFPR
AFF
Fuel Loop
Driveline Mods:
Seattle Rollerbearing shifter
RPS Max Series 6 Puck
RPS Flywheel
PST Carbon Drive Shaft
NBT Quadco XR Output Shaft
NBT Quadco XR TC Spool
3SX SS Clutch Line
Full LSE SS T-Case (Assembled by Pampena)
Solid Shifter bushings
Braking:
iRotors Crossdrilled/slotted
iRotors Ceramic pads
SS Braided lines
ABS Delete
Wheels and tires:
10th Anniversary SVT wheels with BFG Super sport A/S
5zigen FN01rc 17x8 with nankang NS1 (full set)
5zigne Fn01rc 17x9 no tires yet (full set)
16x7 volk te37 with hoosier qtp slicks
Electronics / Ignition:
Blitz Dual Solenoid Boost Controller
Greddy Turbo Timer
Autometer 52mm Boost Gauge
Apexi S-AFC2
MSD DIS-4 Plus
MSD Tach Adapters
MSD Ignition Coils
innovate xd16 w/ lc1 wideband
Chrome Flash ECU
Other:
NGK Spark Plugs
NGK 8.5mm Ignition Wires
