Page 95 of 135 FirstFirst ... 45859394959697105 ... LastLast
Results 941 to 950 of 1341
  1. #941
    Small amount of brassy looking bits came from the first filter.
  2. #942
    GREASE BUNNY
    VA
    Bearings?
    Can a little of that be expected on a new build?
  3. #943
    Used a throw away $8 filter for the first 10 minutes, then went to the bigger HP2007 K&N. If I get flakes in the oil that will be changed probably tomorrow, I will be yanking the damn thing out, and putting her back on the stand...
  4. #944
    The spec sheet from the machine shop
    Sent from the Man Cave!
    *\( ^o^ )/*
  5. #945
    1.9 @ 79ft??? What is 1.9?
  6. #946
    I don't bite
    Southern IN
    1.9 thousandths at 70 ft lbs tq on mains I assume.
  7. #947
    VR-3747 :D Not Verified
    Dayton Ohio
    .0019 @ 70 ft/lb
  8. #948
    I don't bite
    Southern IN
    Echo?
  9. #949
    You shouldn't be having a problem with those clearances. Did you use a new oil pump and check the tolerances in it?
    That oil is too dirty. It should be much cleaner (particle-wise). Discoloration is normal if you used assembly lube.
    What was in the oil system that was reused? Oil lines, cooler, lifters, etc. Something wasn't cleaned out well enough. I didn't want to believe it either with my builds but that's more than likely the cause.
  10. #950
    Pump had 3k or less, the returns were cleaned and reused, all else new.
