Page 86 of 135 FirstFirst ... 3676848586878896 ... LastLast
Results 851 to 860 of 1341
  1. #851
    Low & Slow verified
    Fortson, GA
    Quote Originally Posted by Nihil View Post
    Interesting. I saw someone post a pic on the FB group of their blue coating wearing off too, no mention of noise though, they were just asking if it was normal. I'm sure Chris will have all the answers and will help if any issues arise.
    I have seen a few posts about kevlars knocking teeth off the cam sprockets as well.
    Jeff
  2. #852
    Quote Originally Posted by kywhitelightning View Post
    Jeff
    Is this serious, or in jest? LOL I can't imagine how that would happen...
  3. #853
    Secret Lurker Man! verified
    7/10/06 or somethin
    Bend, Oregon
    Sounds a little far fetched to me, there are more tards on FB than smarts. Every now and then there's somethin interesting to read though.
  4. #854
    The tensioner did however extend back out when I stuck a screwdriver between it and the arm of the pulley. It remained tensioned, but I did not let it sit to see more than 10 minutes to see if it would collapse again. I assumed that it was strong enough to stay while hand turning, but collapses while engine running. Yes I got very lucky!
    Sent from the Man Cave!
    *\( ^o^ )/*
    The tensioner collapses when the engine is running? damn!
    I was going to say they all will collapse when they sit for a while. Well it depends on where the engine stops anyway. At TDC I’ve never seen one do it but if the engine stops in a place where the cams are pulling on the tensioner then it will compress. As soon as it starts to turn over it should pop out.
    After I set timing I put it back to TDC and come back an hour later. If I can still slide the pin in and out then I go with it, if not I do it again until I can.
    Yeah at this point I am removing all doubt. Tired of chasing my ass around, and no tuning being had...
  6. #856
    Twin Turbo verified
    Melbourne, Australia
    There was s thread somewhere showing what a kevlar belt did on a set of alloy adjustable cam gears on an evo. It wore the gears down badly. I have seen no posts about this on steel gears.
    Sent from my GT-I9300 using Tapatalk
    Waiting install
    Build Thread
  7. #857
    GREASE BUNNY
    VA
    I'm your biggest cheer leader right now!
  8. #858
    Unfortunately I only found to put them in a vice, and re-pin in my search of the subject. I now know!
    Sorry if I'm misunderstanding, but is the correct way to let the fully extend, then put it in a vise to retract it and then repin it, then install it? Or is this wrong?
    -Tyler
  9. #859
    Proper way is to not let it extend until installed. Even when installed it should stay in the same position. I forgot to put the pin in when I pulled it...
    In other news, I have located a lower plenum to remove that from the equation. Picking that up tomorrow, and the Ninja delivery truck should be visiting by the weekend.
  10. #860
    Huh, that's interesting. I did my t-belt last year. OEM tensioner, and Gates belt, water pump and idlers. The instruction, with the gates stuff, specifically said allow the pin to fully extend and then retract it. Me and my dad looked at each other and scratched out heads, and said " I guess we put it in the vise to retract it". So we did just that. Granted my car hasn't been on the road in quite some time (completely non-related). So i couldn't tell you, from my experience, if that was the right thing to do. But I do know for sure that the instructions said to let it fully extend and then retract it Before installing it.
