You forget, I have seen your fence!
hey hey hey.... don't knock it till you've tried it...
Car was neglected due to the following rabbit trail.
Looks nice.
It DOES look nice, but im thinkin it wont keep much in (or out) in its current state...
...so, next weekend then?
It is only to prevent the sneaky little beast from visiting the neighbor across the street on the down low. She won't go over when in plain site. lol She goes to the trees, and sneaks her ass over. Training collar, and the rest of the front fenced to match, and problem solved.
Yes next weekend!
So yea on the way home I did a quick 3rd gear check to see if the MBC would work... yea not so much...
I let off when I seen the gauge pass 20 but I think it hit 25-27PSI before I let off, not as bad as the 30PSI LICP coupler destruction from earlier...
Also put a tool kit in the car...LOL
LOL! Need to run a dedicated line for the BC, and make sure it is connected proper. Thing will be a beast when you get it all sorted out. The clamps held eh? lmao...
I think my plan is to while in San Diego next week get some vacuum line from my sources and then use that to run the dedicated MBC line. Also get a exhaust gasket as I was right once I resealed that area it doesnt idle pegged out lean anymore.. but I am sure the 1st 20+PSI run it will blow that shit right out.
Damn, that fence does look nice.
Question,
Did you ever get a weight of one of your wheels w/ the tire on?
