Page 58 of 135 FirstFirst ... 848565758596068108 ... LastLast
Results 571 to 580 of 1341
  1. #571
    I don't bite
    Southern IN
    Is it fuel or coolant in oil?
  2. #572
    Unsure, I can't smell, but I believe coolant.
  3. #573
    All oil left in the DP looked like mixed. All oil elsewhere had no contaminants in it. I need to remove the IC, and drain it to see if oil is contaminated there.
  4. #574
    well at least the feeds weren't plugged
  5. #575
    JNS Engineering verified
    San Jose, CA
    OMG I can't believe this happened. Hope the new turbos are not damaged
  6. #576
    Turbs will be fine. Worst case might need to put seals in it. Awaiting instructions from Dan.
  7. #577
    Also, wife says smells like fuel, but it is a green tint so unsure. With all the priming, and fuel dump that was done It more than likely has all both in it.
  8. #578
    Looks like the hole is clogged....
    Post via Tapatalk
  9. The Following User Says Thank You to FeaRpb For This Useful Post:
  10. #579
    The Panda Not Verified
    Washougal WA/Portland OR
    Oh shit. Was that th feed or drain line. Looks like he drain. And I would put money on that being coolant. As you know the turbos are water cooled and if the seal wasn't sealing the oil and coolest would mix.
  11. #580
    Yeah there is no way to do that with a feed line. It is threaded, not bolted/gasket.
