Page 48 of 135 FirstFirst ... 3846474849505898 ... LastLast
Results 471 to 480 of 1341
  1. #471
    The controller for the snow performance can be set for load. I just need to be sure it plays nice with chromes output.
    Yeah Larry, I was thinking find knock load, come on at 35% before that, find knock with that, 100% just before that. Having a safe buffer for crap fuels. Thoughts?
    Sent from the Man Cave!
  2. #472
    yes load
    That would seem way better than boost really.
    Dropped the ETS 2.75" which puts it level with the splitter.
    Did a little trimming on the crash bar. Will reinforce later with steel tube. Next will enclose it all with stainless.
    The drive shaft, and exhaust wrapped up!
    I will just use the included snow gal tank for now. I calculated the space above the IC/ crash bar, and can have a 2 gallon tank made to fit in there. Will need to have low reservoirs on each side for feeds. Cornering could create an issue without them.
    There is the battery relocate option for further room, but I want neither the bat, nor the meth tank in the cabin.
    Anyway, still crapton of stuff ahead of me. Still need to bleed rear steering, and all break lines. Run the controller for meth, install ecu, reinstall lcdbc, button up wires, intake, battery, radiator, and ic pipes. Then fluids in the engine, trans, transfer, and rear diff. I am sure I forgot 30% more.
    Edit: body work would be nice too!
  4. #474
    The Panda Not Verified
    Washougal WA/Portland OR
    So close but yet still so far away. Bill make a to do list so that you don't forget. Cross off thing as you go.
  5. #475
    Quote Originally Posted by vr4tune View Post
    Heh, just did right above your post!
  6. The Following User Says Thank You to CoopKill For This Useful Post:
  7. #476
    VR-3747 :D Not Verified
    Dayton Ohio
    T\Pretty sure the bottle you are referring to is the coolant overflow tank from a 98-99. Most of the time it will not fit with larger FMIC set-ups.
    Mine barely fit with my CX FMIC. I use that tank as my Meth tank
    Much alcohol had been drank at that moment. I completely effed it up, you are correct lol
  8. #477
    1993 rt/tt Not Verified
    wa state
  9. #478
    Jul 2011
    Chicago NW burbs
    Lookin good Coop.
  10. #479
    West Islip, NY
    My god. Pretty pretty pretty.
    1991 Dodge Stealth ES
    - Sold
    Sold.
  11. #480
    Quote Originally Posted by wingnut View Post
